Ardunio Micro and external Interrupts
So I have built an Arduino Micro and am using an MPU-6050 on top of that. I have connected the SDA and SCL pins to pins 3 and 4, and those works fine. But I have the Interrupt pin connected to pin 12.
Is there anyway to make pin 12 on an Arduino Micro a external interrupt pin?
No. You could use pin change interrupts, which work on most pins.
Can you explain how I would go about that?
(deleted)
mschindl:
Why not connect it to an external interrupt pin?
...R
Do not cross post.
