Ardunio nano every via MIT invert app
Can ardunio nano every connect to the HC-05 bluetooth via MIT inventor app? I tried ardunio nano every connected to the bluetooth HC-o5 via MIT inventor app so it is not working
You already have this going
here
Ardunio with Bluetooth module hc 05 - Using Arduino / Programming Questions - Arduino Forum
I tried to press the relay on '1' of on and button'2' off so it is not working. HC-05 bluetooth(ZS-040) is pairing to smartphone . I am using ardunio nano and hc-05 blueooth pin rx-tx and pin tx-rx with relay.
Thanks
Nano every(atmega428p) doesn’t receive the data or serial from the HC-05 Bluetooth via a smartphone app, e.g. The problem now is that the Nano does not respond to the HC-05, the code for my relay does not see the Serial or data from the HC-05. However, the Arduino nano(atmega328p) does receive data and serial from the HC-05 Bluetooth via a smartphone app, so it works. I did press the '1' (LED on) and press '2'(led off) so it doesn't receive or serial from the hc-05 bluetooth via a smartphone app.
I believe that one or the other has to be rigged as a 'master' and the other as a 'slave'.
Two BT devices configured as 'slave' cannot communicate to each other.
Thank you for reply. Can smartphone app send to the master or slave (Arduino with HC-05) .
Thanks let me know
A smartphone is a master, it can scan / look / search for available devices. An HC-05 can be configured as M or S. An HC-06 is only ever 'S'.
Thank you so much. I don't have other HC-05 Bluetooth. I have only HC-05 Bluetooth. How do I make ardunio code to pair the master device(HC-05). I have ardunio nano . I cannot two pair HC-05 . Can you send me Arduino code for ardunio nano with hC-05? . Can I use ardunio nano with resistor to pair the bluetooth via the smartphone app?
let me know.
I tried everything so it is not working .
If an AT328 Nano can work correctly with your HC05 and your phone app(Android), I see no reason why a Nano Every should not work.
Please post your code and wiring diagram.
You may want to start development with a standard BT terminal app rather than an MIT app inventor app which you have developed.
