I'm wanting to be able to build an RC model that incoperates ardunio, however instead of using an off the shelf RC transmitter and receiver, I want to build a controller based around an ardunio that communicates with an ardunio in the model.
Here are my questions
I'm sure which method of communication to use: wifi, bluetooth, RF, something else?
For the suggested method of communication is there an tutorial/forum post that focuses on this (all of the communications posts I've found are ardunio to computer/smart phone communication)?
Additional information, I'm not intending the model to be more than 10m from the controller, but would prefer a 20m range for safety. Ultimately the model will have a ardunio mini, and small battery pack, so I don't want the communication method to be too power hungry.
Robin 2, thanks for the info on the Deltino devices they look good.
unfortunately they don't have quite enough input and outputs for what I want to do.
I want to run 3 motors, 2 servos and IR emitter and and IR receiver plus in the future I might want to added gyros.
For your range a Xbee is, as nmap said, rather an overkill. Bluetooth is a very good option in my opinion, and there are various blue tooth libraries available (like this one: http://rockingdlabs.dunmire.org/exercises-experiments/hc05-bluetooth with the HC-O5 blue tooth module which is available on ebay for less than $4.). If that too is not an option, using a IR Led with a remote control is the only feasible option I can think of. To read the remote, the IRRemote library is good: IRremote Library, Send & Receive Infrared Remote Control . Hope this helps!
As said, XBee is probably overkill, but it is very simple if used simply to transfer serial data wirelessly, I'm using it for this purpose for a project which requires a 30m separation between Arduinos and a wireless link between them.
XBee Series 1 was a plug and play replacement for a serial cable.
