Ardupilot and memory
I got stuck with the memory distibution of APM2.8. I know it based on Atmega2560 mcu, and when I came to official website to download firmware I've espied that it's about 690kb [link to firmware] whereas atmega has only 256kb flash memory. How does it burn to MCU ?
The ArduCopter.hex file is a text file and contains additional data that will not end up in the Mega. Further the hex-values are converted to binary data which basically halves the actual data.
Just upload it; if it's too big you will be informed and somebody can take it from there. Looking at the size, you probably need to upload using a ICSP programmer.
When loading that file in AVRDUDESS it tells me
ArduCopter.hex: 244,418 Bytes
The file is in Intel hex format https://en.wikipedia.org/wiki/Intel_HEX
Each line of the file contains 16 bytes of the code for the Mega.
