Are either of these TFT's going to be ok?
Having established that my mega2560/mcufriend 3.5 setup is a tad slow on screen rendering, I'll be looking to source a different display when this project advances, since I still want to use a mega/ megapro and use SPI will either of these displays on ebay be ok?
https://www.ebay.co.uk/itm/3-5-inch-320-480-TFT-LCD-Display-Touch-Screen-for-Raspberry-Pi-3-B-2-Model-B/281630179282?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D52945%26meid%3D2554bd8eff4b410b9056f2bb67f0a333%26pid%3D100005%26rk%3D4%26rkt%3D12%26mehot%3Dpp%26sd%3D152734386296%26itm%3D281630179282&_trksid=p2047675.c100005.m1851
or
Both of your displays are for the RaspberryPi. I am sure that they will "work" with a RaspberryPi.
They use a 16-bit parallel module driven by a shift register instead of a proper SPI module.
No one as written an AVR Arduino library for these abortions as far as I know. The 3.3V hardware seems to be 5V tolerant.
Waveshare have example code for their Arduino-shape equivalent boards but it is not really amenable to using regular Arduino sketches.
Bodmer has written a library for ESP8266 and ESP32. I am sure that this will work fine.
David.
Thanks David, it's worth a punt, so you don't like the look of them then :slight_smile: it should quicker than my current setup though? I'm open to suggestions on what I should buy.....
