Are interrupts handled differently on the Uno 3 vs Uno 4?
I have this code here in my setup
pinMode(2, INPUT); // DATA0 (INT0)
pinMode(3, INPUT); // DATA1 (INT1)
pinMode(RELAY, OUTPUT);
// binds the ISR functions to the falling edge of INTO and INT1
attachInterrupt(digitalPinToInterrupt(2), ISR_INT0, FALLING);
attachInterrupt(digitalPinToInterrupt(3), ISR_INT1, FALLING);
and the sketch works perfectly fine on my Uno 3 but not my Uno 4. I haven't been able to find any information about if interrupts work different on the Rev 4 vs the Rev 3. The code compiles and uploads but the interrupts don't work.
Please show the code in full.
Of course, the interrupts are worked differently because the very different controllers.
Im away from my computer at this time but this is the sketch my sketch was based off of.
  • HID RFID Reader Wiegand Interface for Arduino Uno
  • Written by Daniel Smith, 2012.01.30
  • www.pagemac.com
  • This program will decode the wiegand data from a HID RFID Reader (or, theoretically,
  • any other device that outputs weigand data).
  • The Wiegand interface has two data lines, DATA0 and DATA1. These lines are normall held
  • high at 5V. When a 0 is sent, DATA0 drops to 0V for a few us. When a 1 is sent, DATA1 drops
  • to 0V for a few us. There is usually a few ms between the pulses.
  • Your reader should have at least 4 connections (some readers have more). Connect the Red wire
  • to 5V. Connect the black to ground. Connect the green wire (DATA0) to Digital Pin 2 (INT0).
  • Connect the white wire (DATA1) to Digital Pin 3 (INT1). That's it!
  • Operation is simple - each of the data lines are connected to hardware interrupt lines. When
  • one drops low, an interrupt routine is called and some bits are flipped. After some time of
  • of not receiving any bits, the Arduino will decode the data. I've only added the 26 bit and
  • 35 bit formats, but you can easily add more.
#define MAX_BITS 100 // max number of bits
#define WEIGAND_WAIT_TIME 3000 // time to wait for another weigand pulse.
unsigned char databits[MAX_BITS]; // stores all of the data bits
unsigned char bitCount; // number of bits currently captured
unsigned char flagDone; // goes low when data is currently being captured
unsigned int weigand_counter; // countdown until we assume there are no more bits
unsigned long facilityCode=0; // decoded facility code
unsigned long cardCode=0; // decoded card code
// interrupt that happens when INTO goes low (0 bit)
void ISR_INT0()
//Serial.print("0"); // uncomment this line to display raw binary
bitCount++;
flagDone = 0;
weigand_counter = WEIGAND_WAIT_TIME;
// interrupt that happens when INT1 goes low (1 bit)
void ISR_INT1()
//Serial.print("1"); // uncomment this line to display raw binary
databits[bitCount] = 1;
bitCount++;
flagDone = 0;
pinMode(13, OUTPUT); // LED
Serial.println("RFID Readers");
attachInterrupt(0, ISR_INT0, FALLING);
attachInterrupt(1, ISR_INT1, FALLING);
// This waits to make sure that there have been no more data pulses before processing data
if (!flagDone) {
if (--weigand_counter == 0)
flagDone = 1;
// if we have bits and we the weigand counter went out
if (bitCount > 0 && flagDone) {
unsigned char i;
Serial.print("Read ");
Serial.print(bitCount);
Serial.print(" bits. ");
// we will decode the bits differently depending on how many bits we have
// see www.pagemac.com/azure/data_formats.php for mor info
if (bitCount == 35)
  // 35 bit HID Corporate 1000 format
  // facility code = bits 2 to 14
  for (i=2; i<14; i++)
     facilityCode <<=1;
     facilityCode |= databits[i];
  // card code = bits 15 to 34
  for (i=14; i<34; i++)
     cardCode <<=1;
     cardCode |= databits[i];
  printBits();
else if (bitCount == 26)
  // standard 26 bit format
  // facility code = bits 2 to 9
  for (i=1; i<9; i++)
     facilityCode <<=1;
  // card code = bits 10 to 23
  for (i=9; i<25; i++)
     cardCode <<=1;
  printBits();
else {
  // you can add other formats if you want!
 Serial.println("Unable to decode.");
 // cleanup and get ready for the next card
 bitCount = 0;
 facilityCode = 0;
 cardCode = 0;
 for (i=0; i<MAX_BITS; i++)
   databits[i] = 0;
void printBits()
// I really hope you can figure out what this function does
Serial.print("FC = ");
Serial.print(facilityCode);
Serial.print(", CC = ");
Serial.println(cardCode);
I'd suggest creating an absolutely minimal sketch to test interrupts.
Be careful of this:
attachInterrupt(0, ISR_INT0, FALLING);  // pin 2 represented as interrupt 0
use digitalPinToInterrupt() instead of directly giving interrupt numbers such as 0 and 1 which may be platform dependent.
EDIT
In your code snippet in the OP you appear to have already made this correction to the original code.
