For a project, we are looking for a button that can measure a finger press. Does something like this exist?
We have looked at the force-sensitive resistor, but we were hoping for something more button-like.
some force-sensitive resistor are round and small
There are other looks ( Tension Load Cell)
Load cells are a thing, but they aren't anything like a button.
a typical button is not force sensitive either... so you have to adjust
This would go better with a better description of the project. Just based on what you mention if I wanted to measure the force a finger places on a button I would use a "button load cell" which are very common small load cells. A Google of button load cell will bring up a dozen hits of examples. You don't mention any specific range of expected force? No mention of a budget either? Depending exactly on your application they can be inexpensive to expensive depending on manufacturer and uncertainty.
Ron
Note that electronic organs - the good ones - use not pressure sensing, but velocity sensing. They have a "NC" and a "NO" contact with significant spacing between, and determine the time between when the common leaves the "NC" and when it contacts the "NO".
This is relevant to a musical instrument, but may or may not suit what is asked here,
interesting, I did not know that!
Pressure sensitivity allows for MIDI aftertouch, velocity doesn't - you really want both for MIDI, except for a pure piano emulation where aftertouch isn't meaningful.
