Aref pin for external IC
Hello,
I’m trying to use the Arduino reference voltage (Aref pin) as reference for an external IC (a current sense amplifying ic).
I want to use the 2.56V as reference, how can I measure this voltage? By placing a resistor between GND and Aref? And measuring voltage over that resistor?
The language I’m using is C code and im unsure about the command that I use to make sure the reference voltage is 2.56V as I’m not so familiar with this language.
Command: ADMUX=(1<<REFS1)|(1<<REFS2)
DatCoen
I already solved my problem please ignore :slight_smile:
Coensk
