I have an adxl320 which I have hooked to my diecimila. The diecimila is powered by usb, therefore VCC and AVCC are 5V. (right?). My adxl320 is powered seperately by a 3.7v LiPo battery. When I hook the adxl320 X and Y axis to a voltmeter and move it around, I can see a change in V within datasheet limits. The adxl320 at rest is showing 1.87V, which is what I would expect with a supply of 3.7V. So.........my questions are these:
- Should I be connecting the AREF pin on diecimila to the 3.7 LiPo for better results?
- If I do this, will it destroy my diecimila? (I read somewhere that if AREF is set to an internal setting of 2.56V and you put power to AREF external pin then you get problems in the form of a dead chip)
- If putting 3.7V to AREF is OK, does it need to a ground also and if so, would I connect diecimila ground to the 3.7V LiPo ground? (this doesnt seem right)
4.I'm getting bizarre readings from the ADC when adxl320 is hooked to diecimila. (not very consistent) I've read that you may need an op-amp. Is this true?
As you can tell, I'm new to this, but I'm hooked like a junkie. I wish I was 15 years younger and do college over again.......should've majored in EE.
Thanks a million from a noob !!
