Hallo,
We need help with our AREXX Robot...
We have got HC-06 Bluetooth- Kit, but we dont know how to connect the pins to the Robot....
We already found a program.....
We were successful to connect the HC-06 to our Android mobile, but it didnt move....
CAN you pls help us with our problem...?????
We are sending you the program and the pics from our Robot....
Bluetooth Program:
Arduino-Roboter AAR-04 bluetooth
#include <SoftwareSerial.h>
SoftwareSerial mySerial(8, 4); // RX, TX
char incomingByte;
pinMode(10, OUTPUT);
//pin 9 left backward
pinMode(9, OUTPUT);
//pin 5 right foreward
pinMode(5, OUTPUT);
//pin 6 right backward
pinMode(6, OUTPUT);
//Then set the start value of the signals to zero:
analogWrite(9, 0);
analogWrite(10, 0);
analogWrite(5, 0);
analogWrite(6, 0);
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("hello USB");
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
mySerial.println("Hello, BT");
void loop() // run over and over
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
digitalWrite(6,LOW); digitalWrite(5,LOW); //stop motors
digitalWrite(9,LOW); digitalWrite(10,LOW); //stop motors
if (mySerial.available() > 0) { // if received UART data
incomingByte = mySerial.read(); // raed byte
if(incomingByte == '8') {
digitalWrite(10,LOW); analogWrite(9,200); //##set pin 10 to ground!## set speed left motor 200 backward
digitalWrite(6,LOW); analogWrite(5,200); //##set pin 5 to ground!## set speed right motor 200 backward
delay(500); }
if(incomingByte == '4') {
digitalWrite(9,LOW); analogWrite(10,200); //##set pin 9 to ground!## set speed left motor 200 foreward
digitalWrite(6,LOW); digitalWrite(5,LOW); //make a left turn
delay(500); }
if(incomingByte == '2') {
digitalWrite(5,LOW); analogWrite(6,200); //##set pin 6 to ground!## set speed right motor 200 foreward
delay(500); }
if(incomingByte == '6') {
digitalWrite(5,LOW); analogWrite(6,200); //##set pin 5 to ground!## set speed right motor 200 backward
digitalWrite(9,LOW); digitalWrite(10,LOW); //make a right turn
delay(500); }
if(incomingByte == '5') {
