argument in function pass by pointer dosent change
I try modify example "BlinkWithoutDelay", but parameter ledState don't change properly
Please tell me, what i do wrong?
PS sorry for my english
const int ledPin3 =  3;      // the number of the LED pin
// Variables will change :
int ledState3 = LOW;             // ledState used to set the LED
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis3 = 0;        // will store last time LED was updated
// constants won't change :
const long interval3 = 1000;           // interval at which to blink (milliseconds)
  // set the digital pin as output:
  pinMode(ledPin3, OUTPUT);
void timeToBlink(unsigned long currentMillis, unsigned long previousMillis, int* ledState, long interval, int ledPin) {
  if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (*ledState == LOW) {
      *ledState = HIGH;
      *ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, *ledState);
  timeToBlink(currentMillis,previousMillis3, &ledState3, 1000,3);
How does it change?
You could, and in your case SHOULD, use pass-by-reference, instead of a pointer.
         int &ledState,
         long interval,
         int ledPin)
Then, call it:
   timeToBlink(currentMillis,previousMillis3, ledState3, 1000, 3);
In the implementation, treat ledState just like any other argument that was passed by value. The modification WILL be reflected in the caller, though.
Your problem is not the ledState, but the fact that you do not update previousMillis,
but a local copy of that variable, pass a pointer (or reference) to that too.
void timeToBlink(unsigned long currentMillis, unsigned long* previousMillis, int* ledState, unsigned long interval, int ledPin) {
  if (currentMillis - *previousMillis >= interval) {
    *previousMillis = currentMillis;
      *ledState = HIGH;
      *ledState = LOW;
  timeToBlink(currentMillis, &previousMillis3, &ledState3, 1000, ledPin3);
Whandall:
Thank you! i'm even didn't think about it
PaulS:
How does it change?
Why i should use pass-by-reference? because it more safer or just because it simpler?
Both
ispite:
References or pointers are both methods to pass a variable by reference.
The difference is the implicit dereference of the pointer that makes the reference,
so you can use '.' instead of '->' and there is no arithmetic defined for references like it is for pointers.
