Arithmetic Issue
So, I was trying to make some simple code that would start A at ten, start B at one, and every loop, increase B by one, and add that to A, and the result goes in C, so it would be like this:
11, 13, 16, 21, 26, etc
But the code only adds 1 to A and prints it.
Code:
int a = 10;
int b = 1;
int c = 0;
const int delaySpeed = 1000; // Speed of output. Default one second
void increaseAmount() {
  b = b + 1;
  c = a + b;
  Serial.println("Ready");
  delay(delaySpeed);
  increaseAmount();
  Serial.println(c);
Thanks for help!
  c = a + b;
try
c += (a + b);
It's doing exactly what you're telling it to - which is something different from what you want.
Do it out by hand (this is what you should always do when you run into an issue like this):
a=10
b=1
c=0
First round:
b=b+1 (1+1=2 - b is now 2)
c=a+b (10+2=12 - c is now 12)
Second round:
b=b+1 (2+1=3 - b is now 3)
c=a+b (10+3 = 13 - c is now 13)
and so on.
BulldogLowell:
  c = a + b;
try
c += (a + b);
Sorry, That didn't work.
DrAzzy:
a=10
b=1
c=0
First round:
Second round:
and so on.
I forgot to mention
B does not increase, It stays at 1
so the output is this:
10
11
12
13
14
15
16
17
18
19
20
etc
B does not increase
How do you know this?
10
11
12
13
14
15
16
17
18
19
20
That's what happens when you increment by one.
No. The point is that you never change the variable a. So b goes 2, 3, 4 etc but you keep adding that to 10.
What you need to do after incrementing b is add it to the previous RESULT not to a which is still 10.
Steve
