system
August 17, 2012, 11:03am
1
Look at this simple arithmetic line:
long icr1_count = 16000000 / (20000 * 2);
Initially, the "20000" is a defined constant in a macro, I changed it to the real value to debug.
I used Serial.print() to see the value of icr1_count , and its value is: -626
It is negative.
Now I changed the line, I typecasted it:
long icr1_count = 16000000 / (long)(20000 * 2);
The serial monitor says: icr1_count = -626
It was still wrong.
I then tried this:
long icr1_count = 16000000 / ((long)20000 * 2);
Serial monitor says: icr1_count = 400
Can you please explain what just happened?
Thanks. =)
system
August 17, 2012, 11:12am
2
Signed 16 bit arithmetic happened.
long icr1_count = 16000000L/ (20000L * 2)
system
August 17, 2012, 11:30am
3
AWOL:
Well, that is obvious. Also is this a valid notation in C: 20000L ? This is the first time I've seen it..
Then if this works, why does typecasting (20000 * 2) didn't work?
system
August 17, 2012, 11:32am
4
Yes, that's why I showed it to you.
Because 40000 > 32767
system
August 17, 2012, 11:41am
5
Ah, so intermediate calculation values are stored as int by default? OK=)
Thanks =)
Intermediate calculation values on ints are stored handled (not necessarily stored) as int.
system
August 18, 2012, 11:40am
7
Well, when they are handled, the values reside in the memory right? So i think "stored" is also correct. Everything are stored in the registers, its just how the cpu interpret them.
system
August 18, 2012, 1:51pm
8
wakoko79:
It's only semantics, but 'handled' is the more correct term. In other words, what code is generated in order to evaluate the expression you coded.
