Arithmetic with variables, how to?
Can you teach me how to do basic math? :smiley:
The only compile issue seems to be my variable arithmetic towards the bottom of the global variables.
I know I need to define “remaining,” but what’s the proper format to do math that way?
#include <Servo.h>
#define NOTE_C2  65
#define NOTE_E2  82
int melody[] = {NOTE_E2, NOTE_C2};
int noteDurations[] = {4, 4};
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x27 for a 16 chars and 2 line display
//int motorPinA = 10;
int ledPinGREEN = 3;
int ledPinRED = 2;
int ledPinYELLOW = 1;
int repetitions = 0;
int iterations = 0;
int days = 0;
//int motorPinB = 5;
//int motorPinC = 8;
//int servoA;
//int servoB;
//int servoC;
Servo servoA;
Servo servoB;
Servo servoC;
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
//Servo myservo;  // create servo object to control a servo
// a maximum of eight servo objects can be created
int servoPosA = 0;    // variable to store the servo position, all sevo positions start at zero, as they should.
int servoPosB = 0;
int servoPosC = 0;
int days() - int iterations() = int remaining();
  int ledPinGREEN;
  int ledPinRED;
  int ledPinYELLOW;
  //int motorPin;
  //pinMode (motorPinA, OUTPUT);
  pinMode(ledPinGREEN, OUTPUT);
  pinMode(ledPinRED, OUTPUT);
  pinMode(ledPinYELLOW, OUTPUT);
  int repetitions;
  int iterations;
  int days;
  int myservo;
  //int motorPinB;
  //pinMode(motorPinB, OUTPUT);
  servoA.attach(5);  // attaches the servo (A) on pin 5 to the servo object
  servoB.attach(8);  // a servo (B) is attached to pin 8
  servoC.attach(9);  // a servo (C) is attached to pin 9
  lcd.init();     // initialize the LCD
  // Print a message to the LCD.
  lcd.backlight();
  lcd.print("remaining()"); //make the LCD display the remaining pills in the prescription
    for(int days=0;days<40;days++)
    if(iterations % 2 == 0)
      analogWrite(ledPinGREEN, 1023);
      analogWrite(ledPinRED, 1023);
    if(iterations >= 2)
      //analogWrite(motorPinA, LOW);
      analogWrite(ledPinYELLOW, 0);
      //Servo A needs to go to zero, 0, closed, and stay there
      for(servoPosA = 90; servoPosA>=1; servoPosA-=1)     // goes from 180 degrees to 0 degrees
        servoA.write(servoPosA);              // tell servo to go to position in variable 'pos'
        delay(15);
      for(int repetitions=0;repetitions<2;repetitions++)
        analogWrite(ledPinYELLOW, 1000);
        //Servo A needs to go to 90 degrees, open
        for (int thisNote = 0; thisNote < 2; thisNote++)
          int noteDuration = 1000/noteDurations[thisNote];
          tone(8, melody[thisNote],noteDuration);
          int pauseBetweenNotes = noteDuration;
          delay(pauseBetweenNotes);
          // stop the tone playing:
          noTone(8);
        for(servoPosA = 0; servoPosA < 90; servoPosA += 1)  // goes from 0 degrees to 180 degrees
        {                                  // in steps of 1 degree
          delay(15);                       // waits 15ms for the servo to reach the position
          delay(15);
        //analogWrite(motorPinA, 70);
        delay (500);
        //servo A needs to be at 0, closed
        iterations++;           // # value of iterations is counted up by one.
        if(iterations % 2 ==1) // this will devide iteraions by two and every time there is a remainder of one (AKA each time there is an odd number, AKA every other iteration, an (#.5 number) because that remainder 1 gets divided by two to make a .5*2 = 1, AKA once per day!)
          // This means that we can give her the twice-a-day-pills and then give her the once a day pills! We just need to adjust the timeing to match a 24-hour day!
          delay(10); //debounce the system
          //make servos B and C run for once a day
          //analogWrite(motorPinB, 80);
          for(servoPosB = 0; servoPosB < 90; servoPosB += 1)  // goes from 0 degrees to 180 degrees
            servoB.write(servoPosB);              // tell servo to go to position in variable 'pos'
          for(servoPosB = 90; servoPosB>=1; servoPosA-=1)     // goes from 180 degrees to 0 degrees
            delay(15);
          for(servoPosC = 0; servoPosC < 90; servoPosC += 1)  // goes from 0 degrees to 180 degrees
            servoA.write(servoPosC);              // tell servo to go to position in variable 'pos'
          for(servoPosC = 90; servoPosC>=1; servoPosC-=1)     // goes from 180 degrees to 0 degrees
            servoC.write(servoPosC);              // tell servo to go to position in variable 'pos'
            delay(15);
          //delay(300);               Motor A and Motor B may have a need for different speeds, depending on the size and shape of each of the various pills we dispense. Use this code if this is necessary
          //analogWrite(motorPinC, 80);
          delay(50); //how long the motors need to run to spit out exactly one pill of each
          // leave servos B and C stay off on the even(second) run of servo A, meaning that A gives twice a day while B and C give once a day.
          for(servoPosB = 90; servoPosB>=1; servoPosB-=1)     // goes from 180 degrees to 0 degrees
            delay(15);
            delay(15);
          //analogWrite(motorPinB, LOW); //this is a pill that is given only once a day, motor left off
          //analogWrite(motorPinC, LOW); //this is a pill that is given only once a day, motor left off
    days++;
You can't do maths outside a function definition.
There must only ever be one thing to the left of an = sign.
So it needs to be in a function?
so when I cite that function to the LCD as "remaining()" will I be able to give the LCD that number just the same?
How do I get that variable to produce a numerical figure so that the count will be on the LCD, if its coming out of a function?
The math needs to be in a function the variable definitions need to be outside it.
To get at the number all you need to do is to pass the variable to the alacad function instead of a constant.
This line does not make any sense
In programming terms “int days()” describes a function called “days” that will return an integer value when called. Similarly with iterations() and remaining(). The “()” indicate that the thing is the name of a function.
In mathematical terms “5 - 2 = 3” would make sense - but it is a statement, not a question. If you want a computer to calculate something you must express it as “? = 5 - 2”
Assuming you want integer variable named days, iterations and remaining the correct way to define them is
int days;
int iterations;
int remaining;
Then you can give them values like this
days = 5;
iterations = 2;
remaining = days - iterations;
…R
