Hey,
So my group has recently switched from running our code on an Arduino Mega 2560 to an Arduino Due.
To do this, we basically updated Arduino to the latest version, installed the required drivers, and, upon advice from the internet, installed both Arduino Zero and Arduino Due from the Board Manager.
Unfortunately, every time we attempt to compile this code, we get the same error:
arm-none-eabi-g++: error: CreateProcess: No such file or directory
At first, we tried making sure all of the libraries we mention in the code were in the proper directories
#include <Adafruit_MotorShield.h>
#include <QuickStats.h>
//#include <Wire.h>
They are, with the exception of Wire, which we think is either on the system already, but for right now we've commented it out to solve the g++ error.
So, I have no idea what is wrong, we uninstalled and reinstalled java before downloading the latest Arduino, we reinstalled the Arduino.
This code works to control two Adafruit Motorshields and an amplifier circuit. We are running Arduino 8.1 on Windows 7 Service Pack 1, 64 bit.
Here is the Verbose Output that displays every time we try to compile.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\admin\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\admin\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\admin\Documents\Arduino\libraries -fqbn=arduino:sam:arduino_due_x_dbg -ide-version=10801 -build-path C:\Users\admin\AppData\Local\Temp\arduino_build_33467 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\admin\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.bossac.path=C:\Users\admin\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -verbose C:\Users\admin\Desktop\Cartilage Mapping Folder\diff_working_prototype_r1\diff_working_prototype_r1.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\admin\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\admin\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\admin\Documents\Arduino\libraries -fqbn=arduino:sam:arduino_due_x_dbg -ide-version=10801 -build-path C:\Users\admin\AppData\Local\Temp\arduino_build_33467 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\admin\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.bossac.path=C:\Users\admin\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -verbose C:\Users\admin\Desktop\Cartilage Mapping Folder\diff_working_prototype_r1\diff_working_prototype_r1.ino
Using board 'arduino_due_x_dbg' from platform in folder: C:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11
Using core 'arduino' from platform in folder: C:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11
Detecting libraries used...
"C:\Users\admin\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10801 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON '-DUSB_MANUFACTURER="Arduino LLC"' '-DUSB_PRODUCT="Arduino Due"' "-IC:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/libsam" "-IC:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/CMSIS/CMSIS/Include/" "-IC:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/CMSIS/Device/ATMEL/" "-IC:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino" "-IC:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\variants\arduino_due_x" "C:\Users\admin\AppData\Local\Temp\arduino_build_33467\sketch\diff_working_prototype_r1.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\admin\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10801 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON '-DUSB_MANUFACTURER="Arduino LLC"' '-DUSB_PRODUCT="Arduino Due"' "-IC:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/libsam" "-IC:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/CMSIS/CMSIS/Include/" "-IC:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/CMSIS/Device/ATMEL/" "-IC:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino" "-IC:\Users\admin\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\variants\arduino_due_x" "C:\Users\admin\AppData\Local\Temp\arduino_build_33467\sketch\diff_working_prototype_r1.ino.cpp" -o "C:\Users\admin\AppData\Local\Temp\arduino_build_33467\preproc\ctags_target_for_gcc_minus_e.cpp"
exit status 1
Error compiling for board Arduino Due (Programming Port).
Any advice or help.
Please and thank you!
