I get all the time the serial.prints with the messages. I made it work with on char not an array. What is the syntax in order to work properly.When i call the method i give this:
Motors::manualMotion(90,50,"FORW","BACK");
It does not work.When i use one char like F and B, it works properly.
i also used instead of " " the ' '
stringer:
^ Yes you are correct. My post was in addition to your fix.
However, I think it is still best practice to use defined constants and char* for flexibilty.
While I am a pointer user and just love the things, the string array name -is- a const char *.
Where the char * comes in handy in his code is the function args, he could have just 1 function for both Azimuth and both Pitch moves which would shorten and simplify his code. But I wouldn't make a pointer just to set to a constant string and then pass that to the function when simply passing the array name would do. I might use a small array of pointers and an algorithm to choose which to pass but I'd want a wider set of choices or some possibility of that before going to the trouble.
Hi AWOL, don't const char string arrays stay in PROGMEM anyway? I thought that was told.
