Hello today I worked on this project and in the switch/case I use alot of digitalWrite with 4 leds.
Is there away to write this shorter?
const int buttonPin = A1; // the pin that the pushbutton is attached to
const int ledPin0 = 13; // the pin that the LED is attached to
const int ledPin1 = 12; // the pin that the LED is attached to
const int ledPin2 = 11; // the pin that the LED is attached to
const int ledPin3 = 10; // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 15; // counter for the number of button presses
bool buttonState = 0; // current state of the button
bool lastButtonState = 1; // previous state of the button
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
digitalWrite(buttonPin, LOW);
// initialize the LED as an output:
pinMode(ledPin0, OUTPUT);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
// initialize serial communication:
buttonPushCounter = 0;
while(buttonPushCounter <= 15){
// read the pushbutton input pin:
buttonState = !digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button went from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
// if the current state is LOW then the button went from on to off:
Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state, for next time through the loop
lastButtonState = buttonState;
// turns on the LED every four button pushes by checking the modulo of the
// button push counter. the modulo function gives you the remainder of the
// division of two numbers:
switch (buttonPushCounter) {
case 0:
digitalWrite(ledPin0, HIGH);
digitalWrite(ledPin1, HIGH);
digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin3, HIGH);
case 1:
digitalWrite(ledPin0, LOW);
case 2:
digitalWrite(ledPin1, LOW);
case 3:
case 4:
digitalWrite(ledPin2, LOW);
case 5:
case 6:
case 7:
case 8:
digitalWrite(ledPin3, LOW);
case 9:
case 10:
case 11:
case 12:
case 13:
case 14:
case 15:
// button is released
buttonState = false;
