* LedControl.h - A library for controling Leds with a MAX7219/MAX7221
* Copyright (c) 2007 Eberhard Fahle
* Permission is hereby granted, free of charge, to any person
* obtaining a copy of this software and associated documentation
* files (the "Software"), to deal in the Software without
* restriction, including without limitation the rights to use,
* copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following
* conditions:
* This permission notice shall be included in all copies or
* substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
* EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
* OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
* NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
* HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
* WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
* OTHER DEALINGS IN THE SOFTWARE.
#ifndef LedControl_h
#define LedControl_h
#include <avr/pgmspace.h>
#if (ARDUINO >= 100)
#include <Arduino.h>
#else
#include <WProgram.h>
#endif
* Segments to be switched on for characters and digits on
* 7-Segment Displays
const static byte charTable [] PROGMEM = {
B01111110,B00110000,B01101101,B01111001,B00110011,B01011011,B01011111,B01110000,
B01111111,B01111011,B01110111,B00011111,B00001101,B00111101,B01001111,B01000111,
B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,
B00000000,B00000000,B00000000,B00000000,B10000000,B00000001,B10000000,B00000000,
B01111111,B01111011,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,
B00000000,B01110111,B00011111,B00001101,B00111101,B01001111,B01000111,B00000000,
B00110111,B00000000,B00000000,B00000000,B00001110,B00000000,B00000000,B00000000,
B01100111,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,
B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00001000,
B00110111,B00000000,B00000000,B00000000,B00001110,B00000000,B00010101,B00011101,
class LedControl {
private :
/* The array for shifting the data to the devices */
byte spidata[16];
/* Send out a single command to the device */
void spiTransfer(int addr, byte opcode, byte data);
/* We keep track of the led-status for all 8 devices in this array */
byte status[64];
/* Data is shifted out of this pin*/
int SPI_MOSI;
/* The clock is signaled on this pin */
int SPI_CLK;
/* This one is driven LOW for chip selectzion */
int SPI_CS;
/* The maximum number of devices we use */
int maxDevices;
public:
* Create a new controler
* Params :
* dataPin pin on the Arduino where data gets shifted out
* clockPin pin for the clock
* csPin pin for selecting the device
* numDevices maximum number of devices that can be controled
LedControl(int dataPin, int clkPin, int csPin, int numDevices=1);
* Gets the number of devices attached to this LedControl.
* Returns :
* int the number of devices on this LedControl
int getDeviceCount();
* Set the shutdown (power saving) mode for the device
* Params :
* addr The address of the display to control
* status If true the device goes into power-down mode. Set to false
* for normal operation.
void shutdown(int addr, bool status);
* Set the number of digits (or rows) to be displayed.
* See datasheet for sideeffects of the scanlimit on the brightness
* of the display.
* Params :
* addr address of the display to control
* limit number of digits to be displayed (1..8)
void setScanLimit(int addr, int limit);
* Set the brightness of the display.
* Params:
* addr the address of the display to control
* intensity the brightness of the display. (0..15)
void setIntensity(int addr, int intensity);
* Switch all Leds on the display off.
* Params:
void clearDisplay(int addr);
* Set the status of a single Led.
* Params :
* row the row of the Led (0..7)
* col the column of the Led (0..7)
* state If true the led is switched on,
* if false it is switched off
void setLed(int addr, int row, int col, boolean state);
* Set all 8 Led's in a row to a new state
* Params:
* row row which is to be set (0..7)
* value each bit set to 1 will light up the
* corresponding Led.
void setRow(int addr, int row, byte value);
* Set all 8 Led's in a column to a new state
* Params:
* col column which is to be set (0..7)
void setColumn(int addr, int col, byte value);
* Display a hexadecimal digit on a 7-Segment Display
* Params:
* digit the position of the digit on the display (0..7)
* value the value to be displayed. (0x00..0x0F)
* dp sets the decimal point.
void setDigit(int addr, int digit, byte value, boolean dp);
* Display a character on a 7-Segment display.
* There are only a few characters that make sense here :
* '0','1','2','3','4','5','6','7','8','9','0',
* 'A','b','c','d','E','F','H','L','P',
* '.','-','_',' '
* Params:
* digit the position of the character on the display (0..7)
* value the character to be displayed.
void setChar(int addr, int digit, char value, boolean dp);
//bypostmasterino
*Liest Pixel aus
byte seeLed(int addr, int row, int column);
* Shift the Display up
void shiftUp();
* Shift the Display down
void shiftDown();
* Shift the DIsplay left
void shiftLeft();
* Shift the DIsplay right
void shiftRight();
#endif //LedControl.h
