Array Error
Hello all,
I know this has been asked but I still do not understand the difference. When I compile the following code I repeatedly get the error:
error: invalid types ‘int[int]’ for array subscript
I think it has to do with the difference between int and int* (integer vs pointer) arrays, but I’m not sure how to fix this.
Thanks in advance.
int timer = 1500;
int hold = 3000;
int ledpin = 10;
int *floorarray[] = {0, 0, 0, 0};
  for (ledpin; ledpin<14; ledpin++){
    pinMode(ledpin, OUTPUT);
  for (int buttonpin = 1; buttonpin<5; buttonpin++){
    pinMode(buttonpin, INPUT);
int buttoncheck(){
  int buttonpin = 1;
  while (buttonpin<5){
    if (buttonpin = HIGH){
      *floorarray[buttonpin-1]=1;
      buttonpin = buttonpin + 1;
  return floorarray;
//up loop
  for (int i=1; i<4; i++){
//determine which, if any, floors have been requested
    int a = buttoncheck();
//execute loop if floor pressed
    if(a[i]==1){
      digitalWrite(ledpin, LOW);
      delay(timer);
      ledpin = ledpin + 1;
      digitalWrite(ledpin, HIGH);
      delay(hold);
      a[i]=0;
//execute loop if floor not pressed
    if(a[i]==0 && (a[i+1]==1 || a[i+2]==1)){
      delay(timer);
      delay(timer);
//down loop
  for (int i=3; i<4; i--){
//determine which floors, if any, have been selected
    if(a[i]==1){
      delay(timer);
      ledpin = ledpin - 1;
      delay(hold);
      a[i]=0;
    if(a[i]==0 && (a[i-1]==1 || a[i-2]==1)){
      delay(timer);
      delay(timer);
//return to first floor if nothing selected
  if (a[0]==0 && a[1]==0 && a[2]==0 && a[3]==0){
    delay(timer);
    delay(timer);
Don't put 0 to initialize your pointers in your array, use NULL instead (which is a pointer pointing "nowhere")
(I assume you understand that your floorarray array holds 4 pointers to integers, not integers, right? Your code seems to be confused later on... 8) )
You need to initialize ledpin in the same way as you initialize buttonpin in the next for loop.
Pete
J-M-L: (I assume you understand that your floorarray array holds 4 pointers to integers, not integers, right? Your code seems to be confused later on... 8) )
I suppose my code is as confused as I am.. care to elaborate?
I see you've initialized ledpin by declaring it to be 10. Then in setup() you use it in the for loop to increase it to 14. Later on, once the loop() function is executing, you keep increasing or decreasing ledpin depending up button states. You are going to have to figure out if the value of ledpin is really changing correctly. I don't think it is, but I'll let you sort it out.
Pete
el_supremo:
Pete
ledpin is already initialised to 10, but making that clear wouldn’t do any harm
el_supremo: You are going to have to figure out if the value of ledpin is really changing correctly. I don't think it is, but I'll let you sort it out.
You're right, I guess I hadn't looked at that too closely. Thanks!
I meant do you need pointers in that array or do you need integer values?
Sorry for the late reply. I'm not sure I quite understand the difference. I'm trying to update the values within the array to either 0 or 1 and call on them to check within my loop
Then why do you need an array of pointers?
Just an int floorArray[] = {0,0,0,0}; is what you need to declare your array of 4 values and then floorArray[2] = 1; will set the value. And given you store 0 or 1, no need for that array to hold int, a byte array is plenty: byte floorArray[] = {0,0,0,0};
Also your buttoncheck() function is retuning a pointer to the array instead of an int as you declare. Just declare the function as retuning nothing with void buttoncheck() an de don't do any return in the body of the function - your array is a global variable anyway
