Im fairly new to programming the arduino, i have experience in VB and C#.
I am currently doing a university project which requires me to meaure the frequency of a signal and apply a 2nd order low pass filter to the signal. (bessel filter)
I already have managed to measure the frequency and have called it the variable Freq.
What i now need to do is pass each measured Freq value into an array, then apply the bessel filter to it (basically just a formula to each Freq value based on other previous values in the array).
so something like this (for 100 samples): (how i think id do it in vb)
For (intcount 1 to 100) " this loop passes the frequency data into the array"
Array(intcount) = freq;
for (intcount 1 to 100)
FilteredArray(intcount) = 0.009(array(n)) + 0.01(array(n-1)) +0.009(array(n-1)) +1.7(filteredarray(n-1)) -0.7(filteredarray(n-2))
serial.write(filteredarray) " allows me to see the values for the filtered array
serial.write(array) " allows me to see values of the original array
any way as i odnt have much experience in programming arrays itno the arduino, i was hoping that one of you could perhaps suggest a way to do this^?
Look at this and see whether you can apply any of the ideas to your problem
float rawData[100];
float filteredData[100];
for (int f = 0; f < 100; f++)
rawData[f] = measureFrequency();
filteredData[f] = (0.009 * rawData[f]) + (0.01 * rawData[f-1]) + (0.009 * rawData[f-1]) + (1.7 * filteredData[f-1]);
Serial.println(rawData[f]);
Serial.println(filteredData[f]);
int measureFrequency()
int freq = 0;
//code here to measure frequency and put it in the freq variable
return freq;
Arrays in C are indexed from zero and there is no bounds checking so be careful not to stray outside the declared array dimensions.
