array function printin 23 + 1001+ 9+ 1234+ 987 = 3254
i am trying to print the 5values and also the sum the only what i see is 3254 0 0 0 0 my queastion is why does it print like that and not 23 + 1001+ 9+ 1234+ 987 = 3254 in my serial monitor
  int my_array[5]= {23 + 1001+ 9+ 1234+ 987};
  int i;
 int value =0;
  for (i = 0; i < 5; i++) {
    value += my_array[i];
    Serial.println(my_array[i]);
You have a five element array with one element (the first) initialised to the sum of five constants
Your array has 5 elements numbered 0 to 4 but you are only putting a value in element 0
Array values should be separated by commas
i understand i have 5 integers in one array
so i would be like int my_array[1]= {23 + 1001+ 9+ 1234+ 987}; 1 aray whit the calculation
Serial.println(my_array[1]);
Serial.println(my_array[0]);
i changed the program a bit now i got 5 times printed 3254 but not the 23 + 1001+ 9+ 1234+ 987 = 3254
do i need to make a seperate print in function
Are you going to show it to us ?
Serial.print (F("23 + 1001+ 9+ 1234+ 987 ="));
(Uncompiled.Untested. Probably needs more # preprocessor)
opelvectra:
True, you have an array of 5 integers but you are only giving an explicit value to my_array[0]
ill post tommorow my code atm i a reading Arrays in Arduino Sketches
You’re making an ATM?
