Array generated in setup() not working in loop()
/*  I was working on my reflow oven program when I stumbled into this
 *  conundrum. I want to stuff the reflow profile into an array and
 *  then send the second by second temperature to the PID and let the
 *  oven heat along the profile.  I ran into a problem using values from
 *  the array in the loop() function.  I isolated the pertinent code in the
 *  interest of brevity.  It fails in exactly the same manner as my full
 *  code.
 *  Using Arduino 1.8.1 and Arduino Nano in Windows 10.
double Profile[220], DegPerSec, Setpoint=0;   // global declarations
  while (!Serial);        // wait for Serial Port to open
  Serial.begin(9600);     // set the baud rate
  CalculateProfile();     // stuff heat values into Profile[]
  Profile[10]=30.0;       // set a value for debug purposes
  /* Right here, if there is no "Setpoint=20.0;", then the program seems to lock
   * up.  The Serial.println functions never occur.  The Serial Monitor shows no
   * activity.  If I DO have the "Setpoint=20.0;", then everything works.
   * Is this something that I do not understand about arrays?  I am pretty new
   * so I am sure that I am missing something obvious but I cannot find anything
   * in documentation.  I stummbled onto how to get it to work, ie. the
   * "Setpoint=20.0;" declaration...
   * Remove the comments slashes in the next line to watch it work
   * Add the comments slashes to watch it fail
  //Setpoint= 20.0;
  Serial.println("Start of loop");
  Serial.println(Profile[10]);
  Serial.println(Setpoint);
  Setpoint=Profile[10];
  delay(2000);
/* CalculateProfile() calculates the heat curve for the selected
   solder paste and puts the temps into an array
void CalculateProfile() {
  // calculate the Preheat ramp, starting at 20.0 degrees
  DegPerSec = (150 - 20.0) / 90.0;
  for (int x = 0; x < 91; x++)
    Profile[x] = (x*DegPerSec) + 20.0;
  // Calculate the Soak ramp
  DegPerSec = (180 - 150) / 90.0;
  for (int x = 91; x < 181; x++)
    Profile[x] = (x - 90)*DegPerSec + Profile[90];
  // Calculate the Reflow ramp
  DegPerSec = (220 - 180) / 30.0;
  for (int x = 181; x < 221; x++)
    Profile[x] = (x - 180)*DegPerSec + Profile[180];
That's certainly wrong, since it will set the 221st element of your 220 element array. (You have 0 to 219...)
That will overwrite "something" and cause unknown behavior.
That was it. I had no idea that going outside the array size could derange matters so badly. Everything is working as it should now.
Thank you for your help.
Ron
Yeah, C doesn't do any bounds checking on array accesses, so writing beyond the end of the array will overwrite some random piece of RAM; something that could be not noticed at all, or something that is critical to the operation of the program.
