Array index loops automatically after it reaches
When I attempt to increment an index that will be later used in an array, the index is reset. Below are some simple examples:
int i = 0;
int vector[] = {0, 0, 0};
  Serial.print(i);
  vector[i] = 0;
  i++;
Output in Serial Monitor:
01234012340123401234012340123401234.......
If the array is not accessed by commenting out that line, the index counts as expected
int i = 0;
  Serial.print(i);
//  vector[i] = 0;
  i++;
01234567891011121314151617181920212223242526272829303132333435......
Increasing the size of the declared array increases the value i will count to:
int i = 0;
int vector[] = {0, 0, 0, 0};
  Serial.print(i);
  vector[i] = 0;
  i++;
012345012345012345012345012345012345012345012345012345.....
Is the compiler somehow trying to prevent writing to unallocated memory space?
You're writing beyond the bounds of the array. Results will be unpredictable.
I see, thanks. I have a lot more experience with interpreted languages like MATLAB and am used to the interpreter throwing runtime errors if you try to access out of the bounds of an array.
