Array Issue
This is the error:
Arduino: 1.6.5 (Windows 8.1), Board: “Arduino/Genuino Uno”
toneMultiple.ino: In function ‘void setup()’:
toneMultiple:23: error: invalid types ‘int[int]’ for array subscript
“Show verbose output during compilation”
enabled in File > Preferences.
This is my code:
#include"pitches.h"
int ledPin1 = 10;
int ledPin2 = 9;
int ledPin3 = 8;
int melody = {
NOTE_C1, NOTE_FS1, NOTE_A1, NOTE_G1, NOTE_C2, NOTE_FS1, NOTE_D1, NOTE_B0
int noteDurations = {
8, 8, 4, 8, 4, 4, 4, 8
//this is the setup for the rgb light
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
//this is the setup for the buzzer
for (int thisNote = 0; thisNote < 8; thisNote++)
int noteDuration = 1000 / noteDuration[thisNote];
tone(8, melody[thisNote], noteDuration);
int pauseBetweenNotes = noteDuration * 1.30;
delay(pauseBetweenNotes);
noTone( 8 );
void loop () {
setColor(255, 0, 0); //red
setColor(0, 255, 0); //blue
setColor(0, 0, 255); //green
setColor(255, 255, 0); //yellow
setColor(80, 0, 80); //purple
setColor(0, 255, 255); //light blue
void setColor (int red, int blue, int green) {
analogWrite(ledPin1, 255 - red);
analogWrite(ledPin2, 255 - blue);
analogWrite(ledPin3, 255 - green);
Hi
You are declaring new a local variable with the same name as your global array variable. This makes a hole in the scope of the global variable, so you can't access it from within setup(). Change the name of the local variable.
AND... EDIT YOUR ORIGINAL POST AND PUT IN CODE TAGS PLEASE!
PaulRB: Hi
No, the global array variable has a different name.
aarg: No, the global array variable has a different name.
aarg... arrg! You're right. Th line should be
int noteDuration = 1000 / noteDurations[thisNote];
Indeed. It's easy to miss. But that comment shows you what the error is on line 23.
