Array memory slot definition errors
Hello,
just a quick probably easy to asnwer question
I have set my code like that:
byte CellCount = 3;
byte BatteryPins[CellCount] = {A0, A1, A2};
and when I put the variable "CellCount" in the array memory definer it simply wont accept it how should I do it?
Thanks for helping.
What version of the IDE are you using and what board?
const byte CellCount = 3;
(See what I did with code tags there ?)
You need to do it like this
The compiler won't accept a variable for an array size definition
...R
Thanks guys that was helpful just tried that new thing...
Robin2:
...R
Can't you just leave it blank?
INTP:
Leave what blank?
...R
I think this is more flexible
byte BatteryPins[] = { A0, A1, A2 };
const byte CellCount = sizeof(BatteryPins);
Whandall:
I can see where you are coming from but I think that will only work if the array is an array of bytes.
Also, I think the choice between your approach and that in the Original Post must take account of the purpose of the array. If the purpose is to set aside a specified amount of space (but not necessarily to fill it immediately) the style in the Original Post is more suitable.
...R
Robin2:
Which the given array is, so what?
Robin2:
Which can only be guessed by the usage of A0 etc, besides that it was only a snippet that was given,
it is not sensible to assume anything IMHO.
const byte CellCount = sizeof(BatteryPins) / sizeof (BatteryPins [0]);
...is better still, IMO.
It teaches good habits and saves tears and prevents hair loss later.
Translates to 'size of all total elements divided by size of one element'
Side question- does the Arduino lib already have defines for A0-A5 = 14-19?
Whandall:
I was just making the point that it is not a general solution.
That was intended to be a general comment, not specifically related to the OP's problem.
I agree 100% that your solution is good for the OP's specific case.
...R
Try printing A0, A1 etc.
What you get depends on what board you are using.
INTP:
Translates to 'number of total elements divided by size of one element'
Not quite. It's the size of the total elements divided by the size of one element.
