Array not empty
This code receives a message that mas a max lenght of 13 characters. This message is stored in strValue. After receiving the message it must be cleared. Placing a NULL character at strVal[0] schould do the job but it doesnt.
#include <LiquidCrystal.h>
#include <HCPCA9685.h>
#define BAUDRATE  9600
#define LCD_ROWS  2
#define LCD_COLS  16
#define I2C_ADR   0x40
#define VERSION   "XtrackTerm V012z"
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
//HCPCA9685 HCPCA9685(I2C_ADR);
  Serial.begin(BAUDRATE);
  lcd.begin(LCD_COLS, LCD_ROWS);
  lcd.clear();
  lcd.print(VERSION);
  delay(2000);
  lcd.clear();
  /* Wake the device up */
  //  HCPCA9685.Init(SERVO_MODE);
  //  HCPCA9685.Sleep(false);
  lcd.setCursor(0, 0);
  //         1234567890123456
  lcd.print("Waiting for data");
  Serial.println(">>initialized");
// Where receiving a string like 123.45,123.67\n
const int MAX_LEN = 14; // the max digits in the number plus decimal point
char  strInput[MAX_LEN + 1]; // add one for the terminating null
char  *strXval;    // ASCII X axis
char  *strYval;    // ASCII Y axis
int str_Index = 0; // conter for receiving string characters
  //Check to see if anything is available in the serial receive buffer
  while (Serial.available() > 0)
    static char strValue[MAX_LEN];  //  hold the incoming message
    char inByte = Serial.read();  //Read the next available byte
    //Message coming in (check not terminating character) and guard for over message size
    if ( inByte != '\n' && (str_Index < MAX_LEN - 1) )
      //         1234567890123456
      lcd.print(" Receiving data ");
      //Add the incoming byte to our message
      strValue[str_Index++] = inByte;
      Serial.println(strValue);
    } // end if
    //Full message received...
      //Add null character to string
      strValue[str_Index] = NULL;
      Serial.println("process data");
      strValue[0] = NULL;  // Clear the array
      str_Index = 0; // reset array index
    } // end else
  } // end while
} // end loop
Any suggestions, Harry
Please explain what is expected to happen and what is happening
if I enter 1234567890123 for the first time the output looks like this:
[code]>>initialized
1
12
123
1234
12345
123456
1234567
12345678
123456789
1234567890
12345678901
123456789012
1234567890123
process data
[\code]This is correct, but when I send the second message (32310987654321) I see this:[code]
3234567890123
3234567890123
3214567890123
3210567890123
3210967890123
3210987890123
3210987890123
3210987690123
3210987650123
3210987654123
3210987654323
3210987654323
3210987654321
process data
[\code] where can be seen that the array is not empty.
Harry
Setting strValue[0] to 0 clears the string, but then you over-write the 0 with a single byte read from the serial, and the rest of strValue[] is still there - there is no more terminating null until the end of the previous "full message"
When reading strings byte-by-byte, you need to keep propagating the null (or you need to zero out the entire array.)
      strValue[str_Index] =0;
you declared array static, are you using it elsewhere, besides the loop function?
No I only use it in the loop function, actualy only in the while loop
You could move it before while loop and make sure it is zeroed before you use it
if (Serial.available() > 0)
    char strValue[MAX_LEN] = {0};
