This should be relatively straightforward bubble sort, but I can't seem to find the error. In the code, the math 'cube_vol' is the largest variable, and when the array is sorted, it should be the last on the list. But the array doesn't sort. Any ideas?
/**********LIBRARIES**********/
#include <math.h> // https://www.tutorialspoint.com/arduino/arduino_math_library.htm
#define led_1 12 //led on pin 12
pinMode(led_1, OUTPUT);
double length = 8.55; //length of side
double area_math;
double cube_vol;
double sphere_vol;
const double pi_value = 3.14;
const int array_size = 3;
double array_values[array_size] = {0};
area(length, &area_math);
cube(length, &cube_vol);
sphere(length, pi_value, &sphere_vol);
print_values(area_math, cube_vol, sphere_vol);
array_sort(array_size, array_values);
array_insert(area_math, cube_vol, sphere_vol, array_values);
array_print(array_size, array_values);
/**********FUNCTION DEFINITIONS**********/
void area(double length, double*ptrArea)
//square length
*ptrArea = square(length);
void cube(double length, double*ptrCube_vol)
//cube volume
*ptrCube_vol = pow(length, 3); // x to power of y
void sphere(double length, const double pi_value, double*ptrSphere_vol)
//sphere volume
*ptrSphere_vol = (1.33333333) * pi_value * pow((length * 0.5), 3); // where (4 / 3) = 1.3333333
void print_values(double area_math, double cube_vol, double sphere_vol)
//area
Serial.print("Area = ");
Serial.println(area_math);
Serial.flush();
//cube
Serial.print("Cube volume = ");
Serial.println(cube_vol);
Serial.flush();
//sphere
Serial.print("Sphere volume = ");
Serial.println(sphere_vol);
Serial.flush();
void array_insert(double area_math, double cube_vol, double sphere_vol, double array_values[])
array_values[0] = area_math;
array_values[1] = cube_vol;
array_values[2] = sphere_vol;
void array_sort(int array_size, double array_values[])
Serial.println("Sorting...");
//sort via pointers
for (int pass=0; pass < array_size - 1; pass++)
for (int i=0; i < array_size - 1; i++)
if (array_values[i] > array_values[i+1])
//swap positions
double hold = array_values[i];
array_values[i] = array_values[i+1];
array_values[i+1] = hold;
void array_print(int array_size, double array_values[])
for (int i=0; i<array_size; i++)
Serial.println(array_values[i]);
Why not "insert, sort, print"?
see now if work :
you were sorting an empty array.
I changed the order of function calls.
to:
double area_math;
double cube_vol;
double sphere_vol;
//square length
//cube volume
//sphere volume
//area
Serial.flush();
//cube
Serial.flush();
//sphere
Serial.flush();
//sort via pointers
for (int pass = 0; pass < array_size - 1; pass++)
for (int i = 0; i < array_size - 1; i++)
if (array_values[i] > array_values[i + 1])
//swap positions
array_values[i] = array_values[i + 1];
array_values[i + 1] = hold;
for (int i = 0; i < array_size; i++)
Great catch with the program flow error, thanks!
"Great catch" ?
Seriously?
It jumps off the page.
One small thing you might want to add, to save a few cycles: If you get through the entire inner loop of the sort WITHOUT having to do any swaps, you are done. You can skip the remainder of the outer loop.
system
Closed
July 8, 2023, 12:42am
7
