int redGroup[] = {2, 5, 8, 14, 17};
int greenGroup[] = {3, 6, 9, 15, 18};
int blueGroup[] = {4, 7, 10, 16, 19};
int ledCount = 5;
char val[] = "o";
for (int i = 0; i < ledCount; i++)
pinMode(redGroup[i], OUTPUT);
pinMode(greenGroup[i], OUTPUT);
pinMode(blueGroup[i], OUTPUT);
digitalWrite(redGroup[i], 0);
digitalWrite(greenGroup[i], 0);
digitalWrite(blueGroup[i], 0);
if (Serial.available() > 0)
Serial.flush();
for (int i = 0; i < Serial.available(); i++)
val[i] = Serial.read();
Serial.write(val);
if (val[0] == 'o') {
else if (val[0] == 'r')
if(val[1] != 'a')
digitalWrite(redGroup[val[1]], 1);
digitalWrite(redGroup[i], 1);
else if (val[0] == 'g')
digitalWrite(greenGroup[i], 1);
else if (val[0] == 'b')
digitalWrite(blueGroup[i], 1);
else if (val[0] == 'w') {
You can see the setup from the picture, sorry about all the wires. But you can see each group of 5 RGB LEDs. I intend to be able to control each groups colour individually or all together. The problem is if I input, for example, “r2” group 2 should light up the Red LEDs, but only the first group lights up. Even if I input “ra” all of the groups of LEDs should light up red but they aren’t
Is there something wrong with my code that I’m missing?
I expected each character I input through serial would be put into an array, is this not the case? for example if I put "r2" it would mean val = { "r", 2};
If that's not how it works, how do I make it do that?
It would, IF val was big enough. How big IS val?
It's your code. You're supposed to know.
Also keep in mind that Serial data transmission is ssslllooowww. The Arduino can read it orders of magnitude faster than it arrives. You need some way to tell the Arduino to read and store data until the end of the packet arrives, and then use that packet.
would adding a delay after the first read make a difference?
No. That is not the correct approach.
If your commands are always 2 characters, don't read anything until there are two characters to read.
If your commands are variable length, add an end of packet marker (the CR, LF or CR and LF that the serial monitor adds automatically make fine end of packet markers).
