Array of 12 IR Leds
Hello everyone, I need some help for this project,this is my first arduino project.
i'm triyng to fade up and down this array of 12 IR leds from a security cam.
There are 12v (external source).
I was wondering if there is a way to control the amount of current to brighten
up and down the leds by processing sketch or c# ????
Arduino Uno.
I allso was wondering if i take out the LDR and control it by
arduino. Is possible?????
Thank you guys for the support...
FRONT:
BACK:
Hi initzero,
As there appears to be some non passive surface mount components I don't think you can just bridge the LDR and fade the 12V supply up and down. Replacing the LDR with a suitable digital potentiometer (maybe http://uk.mouser.com/ProductDetail/ON-Semiconductor/CAT5132ZI-10-G/?qs=6ARB0lp6jlWjzRAgq8GoEg%3D%3D) might be the better option.
Thank you Riva for the replay!!!
But i don't see how to do it!!! Can you be more specific???
It should work if you remove the LDR and connect the V+ pin to the positive side of the LDR socket and Rw to the other. Vcc, SDA, SCL & GND will need connecting to the Arduino.
A simpler way is to measure the voltage across the LDR and if it's 5V or less then look at this tutorial http://arduino.cc/en/Tutorial/DigitalPotentiometer
I measure the voltage across the LDR and it sets on 8.4v with full light on.
There is another way????? Maybe if i only control the amount of current of the 6.3v(strange)red and yellow wire coming from video board.
Update, Ok after desolding LDR, IR leds was constant on.... That means the LDR decreses the voltage for the leds until it cuts off.... :astonished:
