array of char problem
Hello to all. Does somebody know where my problem is in below code. Very thank you.
char a[20]="123456789";  //default is 123456789
a[20]="ABCDEF";
C:\Users\Leon\AppData\Local\Temp\arduino_modified_sketch_43673\sketch_mar27a.ino: In function 'void setup()': sketch_mar27a:6: error: invalid conversion from 'const char*' to 'char' [-fpermissive] a[20]="ABCDEF"; ^ exit status 1 invalid conversion from 'const char*' to 'char' [-fpermissive]
char a[20]="123456789";  //default is 123456789Declares an array of 20 chars and initialises them with values.
a[20]="ABCDEF";Attempts to set element 20 of the array, which by the way does not exist, to a string of characters.
You cannot change the contents of a whole array on the fly like this but I believe that you could do it using the memcpy() function.
Another problem I have.
char *a="123456789";
char b[20];
b=a;
C:\Users\Leon\AppData\Local\Temp\arduino_modified_sketch_921740\sketch_mar27b.ino: In function 'void setup()': sketch_mar27b:6: error: incompatible types in assignment of 'char*' to 'char [20]' b=a; ^ exit status 1 incompatible types in assignment of 'char*' to 'char [20]'
leoncorleone: Hello to all. Does somebody know where my problem is in below code.
The problem is bullshit coding in this line of your code:
a[20]="ABCDEF";
You better replace with using strcpy() function:
strcpy(a,"ABCDEF");
Standard string handling (using nullterminated strings, char array and char pointers) in the C/C++ programming language is different from dealing with "String object".
While it is perfectly legal to use the equals sign while ititializing a value during declaration of a char array, you have to use the string copy function strcpy() to copy different contents into the array.
