Array of pointers to objects
I’ve built array with Relay objects. Trying to refactor to be an array of pointers to objects how to make that code works:
#define RELAY_ARRAY_SIZE 1
Relay myRelay(&mqttClient, 5, “mqttCommand”);
Relay relays[RELAY_ARRAY_SIZE] = { myRelay };
for (int i=0; i < RELAY_ARRAY_SIZE; i++)
//THIS DO NOT WORK WHEN ITERATE ARRAY OBJECTS
relays[i].setAutoDisableTime(15000);
//THIS WORKS WHEN CALLING OBJECT DIRECTLY
myRelay.setAutoDisableTime(15000);
How should I construct that array to make that work?
The first element of your array is a COPY of ‘myRelay’. Changing that element will not change ‘myRelay’. To make it operate on myRelay you should use an array of pointers:
Relay myRelay(&mqttClient, 5, "mqttCommand");
Relay *relays[RELAY_ARRAY_SIZE] = { myRelay };
     relays\[i\]->setAutoDisableTime(15000);
But when trying to build pointers array:
button.ino:32:42: error: cannot convert 'Relay' to 'Relay*' in initialization
Relay *relays[RELAY_ARRAY_SIZE] = { new Relay(&mqttClient, 5, "mqttCommand") };
Regards,
Ray L.
lonas:
John forgot the address-of operator:
Relay *relays[RELAY_ARRAY_SIZE] = { [color=orange]&[/color]myRelay };
RayLivingstons method is useful if you do not control when the relay is created. However if you do, dynamic memory is just an overhead.
Thanks!!
I would like to do next step :slight_smile:
I have class ButtonHandler where I would like to have as parameter pointer to my array.
I did try to many ways, can You tell me how to do this, please?
What I have is:
we in MAIN scatch we have an array with relays:
Relay *relays[RELAY_ARRAY_SIZE] = { &myRelay };
puting that into:
ButtonHandler buttonHandler(*relays, RELAY_ARRAY_SIZE);
also tried like that
ButtonHandler buttonHandler(&relays, RELAY_ARRAY_SIZE);
  • but still this do not work
I have class:
	class ButtonHandler
		public:
		  ButtonHandler(Relay *relays, int arraySize);
		  void handle(String topic, String mqttCmmand);
		private:
		  Relay *relays;
		  int arraySize;
		  bool isButtonTopic(String topic);
                  void processCommand(String mqttCommand);
                  bool isMatch(String mqttCommand, String relayCommand);
and cpp
#include "ButtonHandler.h"
ButtonHandler::ButtonHandler(Relay *relaysArg, int arraySizeArg) : relays(relaysArg), arraySize(arraySizeArg) {}
How can I have pointer to an array created in main scatch?
RayLivingston:
Now this defines an array of pointers to relay, and attempts to initoalise it with a realy object. This won't work.
If you are happy to simpy have an array of relay objects, then
Relay relays[RELAY_ARRAY_SIZE] = { Relay(&mqttClient, 5, "mqttCommand") };
Should do the job, I think.
Right but now how should I past that array into next class as pointer?
PaulMurrayCbr:
It does work, new returns a pointer.
Ok but how to past that into another class as pointer?
ButtonHandler buttonHandler(relays, RELAY_ARRAY_SIZE);
puting that into:
Since ButtonHandler is set up to take a pointer and relays is already a pointer you don't need any operator to pass it.
Just.
Ok but becasuse of some reasons it do not work like that and in ButtonHandler I have copy not a pointer.
Let me put full code.
Main sketch
#define RELAY_ARRAY_SIZE 2
  Relay(&mqttClient, 5, "ROLLET_UP", true),
  Relay(&mqttClient, 21, "ROLLET_DOWN", true)
ButtonHandler buttonHandlerLib(relays, RELAY_ARRAY_SIZE);
ButtoHandler h
#ifndef ButtonHandler_h
	#define ButtonHandler_h
  #include <Arduino.h>
  #include <Relay.h>
	class ButtonHandler
		public:
		private:
		  Relay *relays;
		  int arraySize;
#endif
ButtonHandler cpp
void ButtonHandler::handle(String topic, String mqttCommand)
  if (isButtonTopic(topic))
    processCommand(mqttCommand);
bool ButtonHandler::isButtonTopic(String topic)
  return topic.equals("/button");
void ButtonHandler::processCommand(String mqttCommand)
  for (int i=0; i < arraySize; i++)
    String relayCommand = relays[i].getCommand();
    Relay relay = relays[i];
    if (isMatch(mqttCommand, relayCommand))
       if (mqttCommand.indexOf("_SHORT") >=0)
         relay.setAutoDisableTime(2000);
         //THIS DO NOT WORK - OBJECT USES STILL DEFAULT VALUE
         //SIMILAR CODE WORKS WHEN IS PLACED IN MAIN SKETCH
       else if (mqttCommand.indexOf("_HOLD") >=0)
          relay.setAutoDisableTime(30000);
       relay.changeState() ;
bool ButtonHandler::isMatch(String mqttCommand, String relayCommand)
  return mqttCommand.startsWith(relayCommand);
relays is an array of pointers. You can't use . notation with pointers. You can't store a pointer in a object.
so what I can to make it work
this also do not work
    String relayCommand = relays[i]->getCommand();
         relays[i]->setAutoDisableTime(2000);
          relays[i]->setAutoDisableTime(30000);
       relays[i]->changeState() ;
error: base operand of ‘->’ has non-pointer type ‘Relay’
String relayCommand = relays*->getCommand();*
Sorry. That was wrong. relays is a pointer to an array. Though, why, I can't imagine.
What was the problem before you made that last change?
Why is relays not an array of pointers?
oqibidipo:
So it does. My mistake.
I tried as array also:
  Relay(&mqttClient, 5, "ROLETY_GORA", true),
  Relay(&mqttClient, 21, "ROLETY_DOL", true)
ButtonHandler
lass ButtonHandler
		public:
		  ButtonHandler(Relay relays[], int arraySize);
		private:
		  Relay relays[];
		  int arraySize;
cpp
ButtonHandler::ButtonHandler(Relay relaysArg[], int arraySizeArg) : relays(relaysArg), arraySize(arraySizeArg[]) {}
Error:
home/../Documents/Apps/arduino-1.6.5-r5/libraries/ButtonHandler/ButtonHandler.cpp: In constructor 'ButtonHandler::ButtonHandler(Relay*, int)':
/home/../Documents/Apps/arduino-1.6.5-r5/libraries/ButtonHandler/ButtonHandler.cpp:3:111: error: expected primary-expression before ']' token
ButtonHandler::ButtonHandler(Relay relaysArg, int arraySizeArg) : relays(relaysArg), arraySize(arraySizeArg) {}
/home/../Documents/Apps/arduino-1.6.5-r5/libraries/ButtonHandler/ButtonHandler.cpp:3:112: error: invalid initializer for array member 'Relay ButtonHandler::relays [0]'
I have a button class named iobutton and the following use of pointers works for me.
This part in globals:
iobutton  turnoff( 4, 20 ); // using jumpers for buttons = dirty buttons
iobutton  turnon( 5, 20 );
iobutton  goslower( 6, 20 );
iobutton  gofaster( 7, 20 );
iobutton  *buttons[ 4 ] =
  &turnoff, &turnon, &goslower, &gofaster
This part in setup()
  for ( byte i = 0; i < 4; i++ )
    buttons[ i ]->startButton();
And this part in loop()
  buttonRead = buttons[ buttonIdx ]->runButton( ); // only running 1 button per loop
BTW, it’s even more “fun” when the array (const data array only) is in PROGMEM.
For me it also work WHEN I use array with pointers in main sketch.
Issue is when I'm trying to move out code responsible for array iteration ( + actions) into external class as an class parameter.
