Hi All,
Can some body help me in understanding the differences between following 2 declarations?
union u2
unsigned long urow2;
struct s2
unsigned int p32 : 1; unsigned int p31 : 1; unsigned int p30 : 1; unsigned int p29 : 1;
unsigned int p28 : 1; unsigned int p27 : 1; unsigned int p26 : 1; unsigned int p25 : 1;
unsigned int p24 : 1; unsigned int p23 : 1; unsigned int p22 : 1; unsigned int p21 : 1;
unsigned int p20 : 1; unsigned int p19 : 1; unsigned int p18 : 1; unsigned int p17 : 1;
unsigned int p16 : 1; unsigned int p15 : 1; unsigned int p14 : 1; unsigned int p13 : 1;
unsigned int p12 : 1; unsigned int p11 : 1; unsigned int p10 : 1; unsigned int p9 : 1;
unsigned int p8 : 1; unsigned int p7 : 1; unsigned int p6 : 1; unsigned int p5 : 1;
unsigned int p4 : 1; unsigned int p3 : 1; unsigned int p2 : 1; unsigned int p1 : 1;
}ss2;
}myunion2[16];
union u2
unsigned long urow2[16];
struct s2
}ss2[16];
}myunion2;
Basically i want to initialize the unsigned int urow2 4-byte variable and then access each of its bits one by one. Which of the above 2 declarations is suitable for doing this?
naeemdotcom:
If you use an 8-bit AVR, both are wrong.
The first uses one two byte variable overlaid with a 32 bit value, 16 times.
The second uses 16 two byte variables overlaid with 16 32 bit values.
Use an unsigned long for urow2 (and the first layout).
holmes4:
2. If you are writing things like this (note the code tags)
etc
then you should be using an array! There are no excuses!
No. There are no arrays of bit-fields.
holmes4:
3. Struct's have nothing to do with this. You should have used a 3D array.
No and no.
holmes4:
5. Just how much SRAM do you think you have? What is 161632*2?
The OP only needs 16*4 bytes with an array of unions.
i can initialize all those 16 variables as unsigned long variables.
but at the same time i want to access each of the bit of 16 variables separately, one by one.
How can i do that using union or some other way?
Either way will work. I think it would be easier to read to have the union represent one unsigned long and make an array of 16 of them (your first example).
