array overshooting
I need to add an offset to where i call my array index in this example +6, i have an interrupt set up that creates a counter which ranges from 0-255, but i also have an if statement which will reset the counter to 0 upon it being equal to 255, i then use this counter to read the index of my array, however when i read it with counter=counter the numbers are smooth but when i add an offset of +6 to the second time i read the table i get a flicker, i think this is down to the counter over shooting 255 and thus looking at the array for an integer which doesn’t exist, how would i read the array table 6 points further down without overshooting my 255, i can obviously do it with a lot of if statements but i will eventually require 40 offsets and 40 different readings so it doesn’t seem very economical.
This is being used to control DMX lighting and so i can see the obvious number flicker/overshoot.
hope this makes sense to someone
// Arduino timer CTC interrupt example
// avr-libc library includes
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#include <DmxMaster.h>
// sine lookup table stored in the flash memory
PROGMEM prog_uchar sinetable[256] = {
  128,131,134,137,140,143,146,149,152,156,159,162,165,168,171,174,
  176,179,182,185,188,191,193,196,199,201,204,206,209,211,213,216,
  218,220,222,224,226,228,230,232,234,236,237,239,240,242,243,245,
  246,247,248,249,250,251,252,252,253,254,254,255,255,255,255,255,
  255,255,255,255,255,255,254,254,253,252,252,251,250,249,248,247,
  246,245,243,242,240,239,237,236,234,232,230,228,226,224,222,220,
  218,216,213,211,209,206,204,201,199,196,193,191,188,185,182,179,
  176,174,171,168,165,162,159,156,152,149,146,143,140,137,134,131,
  128,124,121,118,115,112,109,106,103,99, 96, 93, 90, 87, 84, 81,
  79, 76, 73, 70, 67, 64, 62, 59, 56, 54, 51, 49, 46, 44, 42, 39,
  37, 35, 33, 31, 29, 27, 25, 23, 21, 19, 18, 16, 15, 13, 12, 10,
  9,  8,  7,  6,  5,  4,  3,  3,  2,  1,  1,  0,  0,  0,  0,  0,
  0,  0,  0,  0,  0,  0,  1,  1,  2,  3,  3,  4,  5,  6,  7,  8,
  9,  10, 12, 13, 15, 16, 18, 19, 21, 23, 25, 27, 29, 31, 33, 35,
  37, 39, 42, 44, 46, 49, 51, 54, 56, 59, 62, 64, 67, 70, 73, 76,
  79, 81, 84, 87, 90, 93, 96, 99, 103,106,109,112,115,118,121,124
int count;
int offset = 6;
int speeder = 100; // speed of counter
int dmx_value1;
int dmx_value2;
int dmx_value3;
int dmx_value4;
int dmx_value5;
int dmx_value6;
// initialize Timer1
cli();          // disable global interrupts
TCCR1A = 0;     // set entire TCCR1A register to 0
TCCR1B = 0;     // same for TCCR1B
// set compare match register to desired timer count:
//OCR1A = 15624; Original speed control
OCR1A = speeder;
// turn on CTC mode:
TCCR1B |= (1 << WGM12);
// Set CS10 and CS12 bits for 1024 prescaler:
TCCR1B |= (1 << CS10);
TCCR1B |= (1 << CS12);
// enable timer compare interrupt:
TIMSK1 |= (1 << OCIE1A);
// enable global interrupts:
sei();
  DmxMaster.write(1,0);  //Red
  DmxMaster.write(2,0);  //Green
  DmxMaster.write(3,255);  //Blue
  DmxMaster.write(4, dmx_value1);        //Dimmer
  DmxMaster.write(5, 0);          //Shutter
  DmxMaster.write(6,255);  //Red
  DmxMaster.write(7,0);  //Green
  DmxMaster.write(8,255);  //Blue
  DmxMaster.write(9, dmx_value2);        //Dimmer
  DmxMaster.write(10, 0);         //Shutter
  Serial.print("V1=");
  Serial.println(count);
  Serial.print("V2=");
 /* Serial.print("V3=");
  Serial.println(dmx_value3);
  Serial.print("V4=");
  Serial.println(dmx_value4);
  Serial.print("V5=");
  Serial.println(dmx_value5);
  Serial.print("V6=");
  Serial.println(dmx_value6);
  delay(50);
ISR(TIMER1_COMPA_vect)
  if (count == 255){  //***********If this number is changed to say 240 the flicker no longer occurs
    count = 0;
  else{
    count ++;
dmx();
void dmx(){
  dmx_value1 = (pgm_read_byte_near (&sinetable[(count)]));
  dmx_value2 = (pgm_read_byte_near (&sinetable[(count+offset)]));
Can't you just AND your index with 255?
I had to test this first. Change data type of count and offset to byte, and override the data type in the index where the two values are added.
byte count = 0;
byte offset = 6;
  dmx_value2 = (pgm_read_byte_near (&sinetable[(byte)(count+offset)]));
Does that work for you?
if you don’t put the sine table in PROGMEM but in RAM does that help ?
As AWOL says, because your array is one of the magic sizes (IE a power of 2) you can simply AND the counter to reset it.
if (count == 255)
You should test for >=, if you are incrementing by 6 the values will be either 252 or 258, never 255. 240 works because it happens to be a multiple of 6.
Rob
Don't need an AND. Don't need a comparison. Here is my test code:
byte count = 0;
byte offset = 6;
  Serial.print("Count: ");
  Serial.print(count);
  Serial.print(" + offset: ");
  Serial.println((byte)(count + offset));
  count++;
  delay(100);
surfer tim's solution seems to have worked,
although i'm curious as to why adding byte has stopped it overshooting the array?
and thanks graynomad, as you say i should of had it checking
=255 not just ==255
thanks
You had an int, that's 16 bits (signed) so it would count up to 32k. Changing it to a byte (unsigned char) which is only 8 bits forced a wrap around at 256.
Rob
Thanks for answering that, Graynomad! Nice hat. :wink:
And besides it working, if you use a modified version of the code I posted in reply #5, it is faster and uses less memory, both program and SRAM.
OK I've not studied your sketch thoroughly but I notice you have
void dmx(){
So surely to avoid "overshoot" you want count +offset to be less than 256;
so in your ISR(TIMER1_COMPA_vect) function
if (count == 255)
Should actually read
if ((count+offset) == 255)
@KenF: This takes care of that. Note the addition of the byte data type override in the array index.
SurferTim:
Does that actually work?
I see no reason why it shouldn't, it's just not a situation where I'd use such a method.
I'd feel more comfortable with
dmx_value2 = (pgm_read_byte_near (&sinetable[(count+offset)%256]));
Yes. Run the test code in reply #5.
Why add instructions that are not needed? The byte override does the %256 for you without doing the maths.
