Array passed to constructor reads as integer
Hello,
I'm trying to create a custom Stepper Motor class.
Here's the .h:
#ifndef MyStepper_h
#define MyStepper_h
#include "Arduino.h"
class MyStepper
 private:
 int* _pins[4];
 void CommitStep();
 public:
 MyStepper(int pins[4]);
 MyStepper();
 void Step(int steps);
#endif
Here's the cpp for the constructor:
#include "MyStepper.h"
MyStepper::MyStepper(int pins[4])
 this->_pins=pins;
 pinMode(_pins[0], OUTPUT);
 pinMode(_pins[1], OUTPUT);
 pinMode(_pins[2], OUTPUT);
 pinMode(_pins[3], OUTPUT);
and the arduino code:
#include <MyStepper.h>
int stepperPins[4] = {8,9,10,11};
MyStepper myStepper(stepperPins);
EDIT: both loop and setup are empty, just want to create this object succesfuly
yet I get this problem:
C:\Users\User\Documents\Arduino\libraries\MyStepper\MyStepper.cpp: In constructor 'MyStepper::MyStepper(int*, bool, int)':
C:\Users\User\Documents\Arduino\libraries\MyStepper\MyStepper.cpp:25:13: error: incompatible types in assignment of 'int*' to 'int* [4]'
  this->_pins=pins;
I don't understand. I'm passing an array of size 4, why does it get it as just an int?
Thanks.
int* _pins[4];An array of four pointers to int.
AWOL:
Still don't get it.
Tried to change in the arduino code to:
MyStepper myStepper(stepperPins[4]);
and in the cpp& header to:
MyStepper::MyStepper(int* pins[4])
Edit:
with no success
C:\Users\User\Documents\Arduino\libraries\MyStepper\MyStepper.cpp: In constructor 'MyStepper::MyStepper(int**, bool, int)':
C:\Users\User\Documents\Arduino\libraries\MyStepper\MyStepper.cpp:25:13: error: incompatible types in assignment of 'int**' to 'int* [4]'
  this->_pins=pins;
MyStepper myStepper(stepperPins[4],true,0);What you're trying to do there is pass the fifth element of a four element array.
Put the class code aside, and get comfortable with arrays and pointers.
Hint: the name of an array is a pointer to its first element, and the first element has an index of zero.
kostor:
Still don't get it.
What useful purpose does stepperPins serve?
Indication for which digital pins are used to send signals to the stepper motor from the arduino uno unit.
A great answer for the four values stored in the array stepperPins. But I did not ask about the values stored in the array. I asked about the array itself.
Another way to word the question: Why are you storing the four pin numbers in an array?
AWOL:
At first I was somewhat upset with you. But then I did what you told me to, I re-read the array
guide on cplusplus and changed what it took and it works again now.
So thank you. Really.
So if I ever decide to change it (and I might need to, it's apart of a bigger project), I know where to access it. I also don't want to use 4 integers for code visibility reasons.
But it works now. Thanks for making time for me!
