I've written a library that will fetch setting from SD card. This is the library.
The CONFIG.TXT:
$SSID1=TESTAP1;
$KEY1=TESTAPKEY;
Configfile.h
#ifndef Configfile_h
#define Configfile_h
#include "Arduino.h"
#include <SPI.h>
#include <SD.h>
class Configfile
public:
bool readConfigFile(char* filename);
char* getValue(char* settingName);
private:
File _cfgFile;
uint8_t _filePosition;
uint8_t _workingIndex = 0;
uint8_t _settingNameValuePositions[16][3];
uint8_t _temporaryBufferPosition = 0;
char _temporaryBuffer[32];
char* _filename;
void setPosition(uint8_t mrk);
uint8_t getPosition(uint8_t idx, uint8_t mrk);
void addToBuffer(char inp);
void resetBuffer();
char* requestSetting(char *settingName);
#endif
Configfile.cpp
#include <SPI.h>
#include <SD.h>
#include "Configfile.h"
File _cfgFile;
char* _filename;
bool Configfile::readConfigFile(char* filename)
_filename = filename;
if (!SD.begin()) {
return false;
else {
_cfgFile = SD.open(_filename);
if (!_cfgFile) {
return false;
else {
while (_cfgFile.available()) {
char fileChar = _cfgFile.read();
_filePosition = _cfgFile.position();
switch (fileChar) {
case '
And the test sketch and question here:
#include <Configfile.h>
Configfile configfile;
char* ssid1;
char* key1;
//GET WIFI CONFIGURATION
configfile.readConfigFile("CONFIG.TXT");
ssid1 = configfile.getValue("SSID1");
key1 = configfile.getValue("KEY1");
Serial.println(ssid1); //This will print TESTAPKEY. Why is that? It must print TESTAP1
Serial.println(key1); //This will print TESTAPKEY.
Serial.println(configfile.getValue("SSID1")); //This will print the correct one: TESTAP1
Serial.println(configfile.getValue("KEY1")); //This will print TESTAPKEY
Please let me know if I did something wrong with my library.
Thank you,:
setPosition(0);
case '=':
setPosition(1);
case ';':
setPosition(2);
_workingIndex++;
return true;
char* Configfile::getValue(char *settingName) {
for (int i = 0; i < _workingIndex; i++) {
uint8_t nS = getPosition(i, 0);
uint8_t eQ = getPosition(i, 1);
uint8_t vE = getPosition(i, 2);
bool isFound = false;
resetBuffer();
if (isFound == false) {
for (int g = nS; g < eQ - 1; g++) {
_cfgFile.seek(g);
addToBuffer(_cfgFile.read());
if (strcmp(_temporaryBuffer, settingName) == 0) {
isFound = true;
resetBuffer();
for (int g = eQ; g < vE - 1; g++) {
_cfgFile.seek(g);
if (isFound) {
Serial.print("From getvalue func: ");
Serial.println(_temporaryBuffer);
return _temporaryBuffer;
return "0";
void Configfile::setPosition(uint8_t mrk) {
_settingNameValuePositions[_workingIndex][mrk] = _filePosition;
uint8_t Configfile::getPosition(uint8_t idx, uint8_t mrk) {
return _settingNameValuePositions[idx][mrk];
void Configfile::addToBuffer(char inp) {
_temporaryBuffer[_temporaryBufferPosition] = inp;
_temporaryBufferPosition++;
void Configfile::resetBuffer() {
memset(_temporaryBuffer, 0, sizeof(_temporaryBuffer));
**And the test sketch and question here:**
§DISCOURSE_HOISTED_CODE_3§
Thank you,
