Array question
Hi
I am trying to get use to arrays, i am trying to get a 2 buttons to correspond with an 2 leds on a button press. but its not working and one of the leds is staying can any one
help please?
#include <EEPROM.h>
int val;
int val2;
int addr = 0;
int distbutton = 3;
int storebutton = 4;
int distrelay = 5;
int editbutton = 6;
int comprelay = 7;
int compbut = 8;
int relayid;
int buttonState = 0;
int editstate = 0;
int storestate = 0;
boolean editmode;
byte butid;
const int rotarybut = 2;
int fxbuts [2] = { 3, 8 };
int fxleds [3] = {10, 11, 13};
  //for (int i = 10; i<14; i++)pinMode(i, OUTPUT);
  for(int i = 0; i<4; i++) pinMode(fxbuts[i], INPUT_PULLUP);
for (int i = 0; i<4; i++)pinMode(fxleds[3], OUTPUT);
for(int i = 0; i<4; i++) digitalWrite(fxleds[i], LOW);
void loop(){
// read the fxbuttons
for(int h = 0; h<4; h++){
  buttonState = digitalRead(fxbuts[h]);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is low:
  if (buttonState == LOW) {
    // turn LED on:
   for(int i = 0; i<4; i++) digitalWrite(fxleds[i], HIGH);
//digitalWrite(ledpin3,HIGH);
  else {
    // turn LED off:
    //digitalWrite(ledpin3,LOW);
A three element array doesn’t have an index 3.
fxbuts has 2 elements but you try to read 4? fxleds has three elements but you try to access 4?
On a tablet at the moment but that's what I noticed.l
yep - you are going beyond the bounds of your array...
an Array with 3 elements will have elements at
 x[0], x[1] and x[2]
for (int i = 0; i<4; i++)for (int i = 0; i<4; i++)pinMode(fxleds[3], OUTPUT);
As others have said, thus strays outside the bounds of your array but in any case I expect that you meant
pinMode(fxleds[i], OUTPUT);
Great guys !!
thank you for all the responses.
Greg
is there a way arrays that you can call the leds individually with a button ie. when button dist button calls fxleds 1 (10) in the array. combutton callls fxleds 2 (11)
#include <EEPROM.h>
int val;
int val2;
int addr = 0;
int distbutton = 3;
int ts = 9;
int distrelay = 5;
int editbutton = 6;
int comprelay = 7;
int compbut = 8;
int relayid;
int editstate = 0;
int storestate = 0;
boolean editmode;
byte butid;
int fxbuts [3] = { 3, 8, 9 };
  //for (int i = 10; i<13; i++)pinMode(i, OUTPUT);
  for(int i = 0; i<3; i++) pinMode(fxbuts[i], INPUT_PULLUP);
for (int i = 0; i<3; i++)pinMode(fxleds[i], OUTPUT);
for(int i = 0; i<3; i++) digitalWrite(fxleds[i], LOW);
void loop(){
for(int h = 0; h<3; h++){
    // turn LED on:
   for(int i = 0; i<3; i++) digitalWrite(fxleds[i], HIGH);
  else {
    // turn LED off:
You could have another array for the buttons value and do buttonState[h] = digitalRead(fxbuts[h]);
So you should define this at the beginning by replacing
With
int buttonState[3]; // Will be initialized later
Then read just the 3 buttons states
Then in the code you do another loop to check buttonState[0] to represent fxleds[0], buttonState[1] to represent fxleds[1] etc
This gives you an option to perform some actions based on the status of multiple buttons being pressed, instead of having the info about only 1 button
Alternatively if you don’t need combination of buttons, keep the code simple as it is but instead of turning on and off all LEDs with
Just turn on the one matching the current button
digitalWrite(fxleds[h], HIGH); // h for the for loop you are in
Brilliant!!!!
thanks for taking the time to explain that.
Greg
