Array size
Hey, I have three dimensional array. I need to find the amount of rows in it (example below). How can I do it?
Example array, trying to find value x.
int array[X][2][3] = {
{{1, 2, 3}, {2, 2, 2}},
{{2, 3, 2}, {3, 5, 2}},
...    (n lines)
{{1, 1, 1}, {3, 2, 2}}
I cannot change the structure of the array as it is blueprint for controlling RGB LEDs row by row.
I can't see x in the code that you posted. Perhaps if you had used code tags when you posted it ....
sizeof (array) / 12
Though that's assuming 16 bit ints.
Gollex:
...    (n lines)
The size of your three dimensional array can be determined this way:
int array[][2][3] = {
  Serial.println(sizeof(array)/sizeof(array[0]));
  Serial.println(sizeof(array)/sizeof(array[0][0]));
  Serial.println(sizeof(array)/sizeof(array[0][0][0]));
Wouldn't that be:
  Serial.println(sizeof array         / sizeof array[0]);
  Serial.println(sizeof array[0]     / sizeof array[0][0]);
  Serial.println(sizeof array[0][0] / sizeof array[0][0][0]);
johnwasser:
Wouldn't that be:
Ha! I guess it just depends on what you were getting the sizeof()!
The answer to OP's question are in both our responses...
