How do I store numbers in an array like a list one by one?
example if i do:
int d[3];
void loop
if(blabla){
d[3]= {1}
and then when it loops, I want the output to be d[3]={1,1,1}
How do I do that? The code above seems wrong
example if i do:
int d[3];
void loop
if(blabla){
d[3]= {1}
d[3]= {1}
This will work but the braces are not needed
An example :
byte anArray[16];
const byte NUMBER_OF_ELEMENTS = sizeof(anArray) / sizeof(anArray[0]);
while (!Serial);
for (int index = 0; index < NUMBER_OF_ELEMENTS; index++)
anArray[index] = random(256);
Serial.print(index);
Serial.print("\t");
Serial.println(anArray[index]);
UKHeliBob:
d[3]= {1}This will work but the braces are not needed and will f*u the memory because d[3] isn't declared.
[/quote]
Because you only declared d[0], d[1] and d[2]
septillion:
My fault for not explaining that whilst it will work in general it is incorrect in the case of the OP's code
