Array to String help
I have this function:
void array_to_string(byte array[], unsigned int len, char buffer[])
   for (unsigned int i = 0; i < len; i++)
      byte nib1 = (array[i] >> 4) & 0x0F;
      byte nib2 = (array[i] >> 0) & 0x0F;
      buffer[i*2+0] = nib1  < 0xA ? '0' + nib1  : 'A' + nib1  - 0xA;
      buffer[i*2+1] = nib2  < 0xA ? '0' + nib2  : 'A' + nib2  - 0xA;
   buffer[len*2] = '\0';
The result that I get is:
F555B31F
What do I need to change in this function to get the result (colons added):
F5:55:B3:1F
I'm new to C/C++, so please be gentle :blush:
In practice, is "len" the same value every time you use this function?
If i equals 2, 5 or 8 (There are neat ways to do this using the modulo operator (%) ) put a colon in the array and increment i.
You are writing the two nibbles already, just add a line to write the colon to the buffer after you write the second nibble in your for loop. Make sure to use buffer[i+3+0] , buffer[i+3+1] etc.
BTW: buffer[len*2] is wrong, you probably meant buffer[len*2-1] instead. Make sure to also change this to buffer[len*3-1] if you add the colon after the bytes.
Edit: sorry, my last paragraph is wrong. Don't subtract 1 ...
      if (i == 0)
        sprintf(buffer, "%02x", array[i]);
        sprintf(&buffer[i*3-1], ":%02x", array[i]);
Thank you guys for your quick responses.
@PaulRB yes the len is always 4
@PaulRB is there a way to get it always uppercase?
Oh, yes, sorry. Change the "x" to "X" in sprintf().
Then you don't need array_to_string() at all:
byte array[4] = { 0xF5, 0x55, 0xB3, 0x1F };
char buffer[12];
sprintf(buffer, "%02X:%02X:%02X:%02X", array[0], array[1], array[2], array[3]);
      if (i == 0)
@sakshijn are you suggesting a change? I didn't spot it.
