I am using
digitalread on input 2,3,4 on 1 arduino
digitalwrite on another arduino to trigger led 2,3,4. in consequence.
i want to trigger input 2 on A and light 2 on B and so on. if I press 3 led 3 should light at the other end.
i can do it by sending a message each time input is triggered , but cannot figure out by using Array. i am trying to use nrf24l01 led_remote example (trying to modify)
because i want to have 1 program transceiver.
any help on code example?
the idea:
On the Tx read the pins in the array using a for loop. If any of them have changed since the last time they were read then send the array.
On the Rx, when the array is received read the values using a for loop and set the state of the LED pins
2. An array is a 'packet' of similar things, where they together and one after another. Let us put the variable of Step-1 in the following array named myButton.
bool myButton[3];
for(int i= 0, j = 2; i<3, j<5; i++, j++)
myButton[i] = digitalRead(j); //logic value of DPin-2 (3, 4) goes to array-element myButton[0],...
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
RF24 radio(9, 10);
#define NUM_ITEMS 3
// sets the role of this unit in hardware. Connect to GND to be the 'led' board receiver
// Leave open to be the 'remote' transmitter
const int role_pin = A3;
// Pins on the remote for buttons
const uint8_t button_pins[NUM_ITEMS] = { 2, 3, 4 };
const uint8_t num_button_pins = sizeof(button_pins);
// Pins on the LED board for LED's
const uint8_t led_pins[NUM_ITEMS] = { 2, 3, 4 };
const uint8_t num_led_pins = sizeof(led_pins);
// Topology
// Single radio pipe address for the 2 nodes to communicate.
const uint64_t pipe = 0xE8E8F0F0E1LL;
// Role management
typedef enum { role_remote = 1, role_led } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Remote", "LED Board"};
// The role of the current running sketch
role_e role;
// Payload
uint8_t state[num_button_pins];
uint8_t led_states[num_led_pins];
// Setup
void setup(void)
// Role
// set up the role pin
pinMode(role_pin, INPUT);
digitalWrite(role_pin, HIGH);
delay(20); // Just to get a solid reading on the role pin
// read the address pin, establish our role
if ( digitalRead(role_pin) )
role = role_remote;
role = role_led;
// Print preamble
printf_begin();
printf("\n\rBy Paul Transceiver\n\r");
printf("ROLE: %s\n\r", role_friendly_name[role]);
radio.begin();
radio.setPALevel(RF24_PA_HIGH);
radio.setDataRate(RF24_1MBPS);
radio.setCRCLength(RF24_CRC_16);
// Setup and configure rf radio
if ( role == role_remote )
radio.openWritingPipe(pipe);
radio.stopListening();
for (int i = 0; i < NUM_ITEMS; i++)
pinMode(button_pins[i], INPUT);
digitalWrite(button_pins[i], LOW);
else if ( role == role_led )
radio.openReadingPipe(0, pipe);
radio.startListening();
pinMode(led_pins[i], OUTPUT);
digitalWrite(led_pins[i], LOW);
radio.printDetails();
// Loop
void loop(void)
for (int i = 0 ; i < NUM_ITEMS ; ++i)
uint8_t state = digitalRead(button_pins[i]);
if (state == HIGH)
printf("Now sending...");
bool ok = radio.write( state, button_pins[i] );
if (ok)
printf("ok\n\r");
printf("Check Radio Receiver is ON\n\r");
// Try again in a short while
delay(20);
int i = num_button_pins;
// if there is data ready
if (radio.available())
// Dump the payloads until we've gotten everything
radio.read( state, num_button_pins );
// Spew it
digitalWrite(led_pins[i], state);
Why are these variables bools ?
digitalRead() does not return a bool
Logical common sense -- I am reading 1-bit data from DPin-2; so, I like to save it in 1-bit variable. Do you you think that it does not work for me?
The digitalRead(); returns HIGH or LOW. 0x51 is HIGH compare to 0x03. 1 is HIGH compare to 0. bool for boolean -- a boolean variable can have either of the two states HIGH or LOW; so, it is a two valued variable. The declaration of bool x2; is not challenged by the Arduino IDE/Compiler; so, I am going ahead.
It is not there; but, it has not been challenged by the Arduino IDE/Compiler. Even the following codes that you have termed as 'n...' (I don't want to repeat that word as that vocabulary goes in the very wrong way in our local mindset)' are compiled, uploaded, and executed; it provides fantastic results.
bool myButton[3];
for (int i = 0, j = 2; i < 3, j < 5; i++, j++)
Serial.println(myButton[0], BIN);
You are making things look more complicated than they need be by combining two roles in one sketch. I find it better to write separate Tx and Rx programs
Have these on me (based on Robin2's excellent thread simple RF24)
Tx
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
//not all #defines used but here for documentation
#define CE_PIN 9
#define CSN_PIN 10
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
const byte slaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char txNum = '0';
byte pinStates[] = {};
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000;
Serial.println("SimpleTx Starting");
radio.begin();
radio.setDataRate( RF24_250KBPS );
radio.setRetries(3, 5); // delay, count
radio.openWritingPipe(slaveAddress);
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis)
send();
prevMillis = millis();
void send()
bool rslt;
rslt = radio.write( &pinStates, sizeof(pinStates) );
if (rslt)
Serial.println(" Acknowledge received");
Serial.println(" Tx failed");
Rx
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
const byte thisSlaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
byte dataReceived[3]; // this must match the array in the TX
bool newData = false;
Serial.println("SimpleRx Starting");
radio.begin();
radio.openReadingPipe(1, thisSlaveAddress);
getData();
showData();
void getData()
if ( radio.available() )
radio.read( &dataReceived, sizeof(dataReceived) );
newData = true;
void showData()
if (newData == true)
Serial.print("Data received ");
for (int x = 0; x < 3; x++)
Serial.print(dataReceived[x]);
Serial.print(" ");
newData = false;
This pair of programs sends an array of 3 byte values from Tx to Rx. You need to add the code to read the buttons to populate the array on the Tx and read the array to set the state of the LEDs on the Rx
