I am testing a library i wrote that allows for easy frequency analysis. In my test program, i generate a crude rect signal that is saved as a 128 value float array. When I look at the output (the println seen in the code below), i get some values showing up as -0 or ovf. These can not be set. It works without the library (everything that has anything to do with the FrequencyAnalyzer commented out), but the compiler can't just override already assigned memory, can it?
Test program:
#include "FundamentalFrequencyAnalyzer.h";
FundamentalFrequencyAnalyzer ffa = FundamentalFrequencyAnalyzer();
float samples[128] = {};
memset(samples, 0, 128);
for(int i = 0; i < 128; i++){
Serial.println(samples[i]);
boolean b = 0;
uint8_t j = 0;
for (int i = 0; i < 128; i++) {
samples[i] = b;
if (j >= 16) {
b ^= 1;
j = 0;
j++;
ffa.get128(samples, 1000);
Header:
#ifndef FundamentalFrequencyAnalyzer_h
#define FundamentalFrequencyAnalyzer_h
#include "Arduino.h"
#define WIN_TYP_RECTANGLE FFT_WIN_TYP_RECTANGLE
#define WIN_TYP_HAMMING FFT_WIN_TYP_HAMMING
#define WIN_TYP_HANN FFT_WIN_TYP_HANN
#define WIN_TYP_TRIANGLE FFT_WIN_TYP_TRIANGLE
#define WIN_TYP_NUTTALL FFT_WIN_TYP_NUTTALL
#define WIN_TYP_BLACKMAN FFT_WIN_TYP_NUTTALL
#define WIN_TYP_BLACKMAN_NUTTALL FFT_WIN_TYP_BLACKMAN_NUTTALL
#define WIN_TYP_BLACKMAN_HARRIS FFT_WIN_TYP_BLACKMAN_HARRIS
#define WIN_TYP_FLT_TOP FFT_WIN_TYP_FLT_TOP
#define WIN_TYP_WELCH FFT_WIN_TYP_WELCH
class FundamentalFrequencyAnalyzer {
public:
FundamentalFrequencyAnalyzer(uint8_t windowType);
uint16_t get32(float *samples, uint16_t samplingFrequency);
uint16_t get64(float *samples, uint16_t samplingFrequency);
uint16_t get128(float *samples, uint16_t samplingFrequency);
uint16_t get256(float *samples, uint16_t samplingFrequency);
private:
uint8_t _windowType;
float _vReal32[32];
float _vImag32[32];
float _vReal64[64];
float _vImag64[64];
float _vReal128[128];
float _vImag128[128];
float _vReal256[256];
float _vImag256[256];
#endif
Source:
#include "src\arduinoFFT.h"
FundamentalFrequencyAnalyzer::FundamentalFrequencyAnalyzer(uint8_t windowType)
_windowType = windowType;
FundamentalFrequencyAnalyzer::FundamentalFrequencyAnalyzer()
_windowType = WIN_TYP_RECTANGLE;
uint16_t FundamentalFrequencyAnalyzer::get32(float *samples, uint16_t samplingFrequency)
memcpy(_vReal32, samples, 32);
memset(_vImag32, 0, 32);
arduinoFFT FFT = arduinoFFT(_vReal32, _vImag32, 32, samplingFrequency); // create FFT object
FFT.DCRemoval();
FFT.Windowing(_windowType, FFT_FORWARD);
FFT.Compute(FFT_FORWARD);
FFT.ComplexToMagnitude();
return (uint16_t)FFT.MajorPeak();
uint16_t FundamentalFrequencyAnalyzer::get64(float *samples, uint16_t samplingFrequency)
memcpy(_vReal64, samples, 64);
memset(_vImag64, 0, 64);
arduinoFFT FFT = arduinoFFT(_vReal64, _vImag64, 64, samplingFrequency); // create FFT object
FFT.DCRemoval();
uint16_t FundamentalFrequencyAnalyzer::get128(float *samples, uint16_t samplingFrequency)
memcpy(_vReal128, samples, 128);
memset(_vImag128, 0, 128);
arduinoFFT FFT = arduinoFFT(_vReal128, _vImag128, 128, samplingFrequency); // create FFT object
FFT.DCRemoval();
uint16_t FundamentalFrequencyAnalyzer::get256(float *samples, uint16_t samplingFrequency)
memcpy(_vReal256, samples, 256);
memset(_vImag256, 0, 256);
arduinoFFT FFT = arduinoFFT(_vReal256, _vImag256, 256, samplingFrequency); // create FFT object
FFT.DCRemoval();
