Array with Strings in class
I'm trying to make use of an array inside a class but I get stuck.
The array should become an array of strings.
class myTest{
  private:
    String myArr[];
  public:
String myTest::myArr = {"first element","second element"};
I get the following errors at compilation time:
sketch_dec16a:3:18: error: flexible array member 'myTest::myArr' in an otherwise empty 'class myTest'
String myArr[];
sketch_dec16a:8:16: error: 'String myTest::myArr' is not a static data member of 'class myTest'
sketch_dec16a:8:57: error: conversion from '' to 'String' is ambiguous
You must specify the array size when it's inside a class or struct.
If I do so then I get other errors
class myTest{
  private:
    String myArr[2];
  public:
Errors:
The initial value needs to go in the class definition:
class myTest {
  private:
    String myArr[2] = {"first element", "second element"};
  public:
Or in the class constructor:
class myTest
    String myArr[2];
  public:
    myTest();
    void print(int n)
      Serial.println(myArr[n]);
myTest::myTest() :
  myArr({"first element", "second element"})
  myTest test;
  delay(200);
  test.print(0);
  test.print(1);
void loop() {}
Thanks that solves the problem.
I'm not familiar with the code though.
The colon after the function constructor is new to me.
myTest::myTest() :
I
C++ initialiser list
