Array with User-Defined Function
Hello,
I am trying to learn how to use an array to return several numbers at once from a user defined function.
I keep running into the following error message: invalid conversion from ‘int*’ to ‘int’
Any ideas? Thanks!
int oldArray = {
5, 6 };
int newArray = {
0, 0 };
newArray = plusOne(oldArray, 1);
int plusOne(int inputArray, int indices)
int outputArray[indices];
for (int i=0; i<=indices; i++)
outputArray_=inputArray*+1;_
_
}_
_
return outputArray;_
_
}*_
Functions can return a single value. They can not return an array.
You can pass the array to store the results in to the function, though.
You can return an array if it embedded in a structure.
  int ret_val;
  int oldArray[] = {
    5, 6  };
  int newArray[] = {
    0, 0  };
  ret_val = plusOne(oldArray, 1, newArray);
int plusOne(int *inputArray, int indices, int* outputArray)
    outputArray[i]=inputArray[i]+1;
  return 1; //yeay... success...
This?
Working example, best if done as a sketch and a header file as follows.
 * File - types.h
struct point_t
    short x, y;
 * File - test_sketch.pde
#include "types.h"
point_t funct1()
    point_t pt = { 4, 12 };
    return pt;
    point_t pt  = funct1();
    short   x   = pt.x;
    short   y   = pt.y;
