array
How can u combine several arrays into one?
int all [15];
all = [rpm,pressure,temperatures];// Does not work
where they all are one dimensionals arrays.
Kim
You could either do it with a structure:
typedef struct {
  int temp;
  int pressure;
  int rpm;
} engineVals;
engineVals myData [15];
or with an 'n' dimensional array:
int engineVals [N_VALS][3];
or with three one dimensional arrays.
Lots of ways.
well :
maybe i should clearify that rpm, pressure and temperature are arrays:
int rpm[3] = {1,2,3};
int pressure[5] = {4,5,6,7,8};
int tempertures[4] = {9,10,11,12};
then i want my all array to look like:
all = {1,2,3,4,5,6,7,8,9,10,11,12,13,14}
so i can loop through it and print it to the serial port:
for(int i=0; i<14;i++){
Serial.print(all*);*
Serial.print("\t");
If you actually want to store rpm, pressure and temperature 15 times you should do:
struct data {
  int rpm;
  int pressure;
  int temperature;
data all[15];
//later
int somePressure = all[2].pressure; //retrieve the pressure stored at index 2
[edit]I see AWOL got to it before I did :-[ :D[/edit]
Or:
[BEWARE OF ARRAY BUONDS]
int rpm[3] = {1,2,3,4,5,6,7,8,9,10};
int pressure[5] = {11,20,30,40,50,60,70,80,90,100};
int temperature[7] = {101,200,300,400,500,600,700,800,900,1000};
int* all[3] = { rpm, pressure, temperature };
int somePressure = all[1][4]; //50
Well here is the complete code: Any suggestion to improvement would be great:)
#include <MegaServo.h>
// Constants regarding logging
int loggingIntervalDefault = 1000; //ms
long previousPrint = 0;
int baudrate = 19200;
byte switchPin1 = 12;
bute switchPin2 = 16;
numberOfSensores = 13;
int* all[numberOfSensores];
char* deliminter = "\t";
// constants regarding moving the servo for the webcam
int servoPot  = 12;
int minPos   = 0;
int maxPos   = 180;
byte servoPin = 9;
boolean servoDirection = 0;
int servoPos = 0;
MegaServo servo;
// constants for RPM
volatile byte rpmcount = 0;
unsigned int rpm = 0;
unsigned long timeold = 0;
byte rpmDisplayPin = 11;
int rpmMax = 4000;
int numberOfSamples = 400;
// constants for pressure sensors
byte pressurePins[5] = {3,0,2,1,13};
int pressureMax[5] = {10,10,10,10,500};
// array holding the values
byte pressure[5]     = {0,0,0,0,0};
// constants for temperture sensors
byte temperturePins[5] = {9,10,6,7,8};
byte temperatur[5]     = {0,0,0,0,0};
// constants for volume flow sensors
byte flowPins[2] = {5,4};
int flowMax[5] = {40,150};
byte flow[2]     = {0,0};
// constants for multiplexer
byte S0 = 16;
byte S1 = 6;
byte S2 = 7;
byte S3 = 8;
byte signal = 0;
byte logicArray [16][4] = { {0,0,0,0},
                          {1,0,0,0},
                          {0,1,0,0},
                          {1,1,0,0},
                          {0,0,1,0},
                          {1,0,1,0},
                          {0,1,1,0},
                          {1,1,1,0},
                          {0,0,0,1},
                          {1,0,0,1},
                          {0,1,0,1},
                          {1,1,0,1},
                          {0,0,1,1},
                          {1,0,1,1},
                          {0,1,1,1},
                          {1,1,1,1}};
byte pinSelect[4] =  {S0,S1,S2,S3};
 // Multiplexer
 pinMode(S0, OUTPUT);    // sets the digital pin as output
 pinMode(S1, OUTPUT);    // sets the digital pin as output
 pinMode(S2, OUTPUT);    // sets the digital pin as output
 pinMode(S3, OUTPUT);    // sets the digital pin as output
 // Web camera
 servo.attach(servoPin,800,2200);
 //rpm
 attachInterrupt(0, rpm_fun, RISING);
 // Write
 Serial.begin(baudrate);
 writeHeader();
Serial.print(millis());
Serial.print("\t");
// Move camera
moveServo(servoPos);
// Read rpm
rpmRead();
// Read pressure sensors
readPressures();
// Read temperatures
readTemperatures();
// Read volume flow
readVolumeFlow();
// Write data to serial port
write2Serial();
void write2Serial(){
if(digitalRead(switchPin1) == HIGH){
       loggingInterval = loggingIntervalDefault;// logging at given interval
else if(digitalRead(switchPin2) == HIGH
       loggingInterval = 0;//logging as fast as possible
else{
 return;// No logging
 if(millis()-previousPrint>loggingInterval){
   all = [rpm,pressure,tempertures,flow];
   for(byte i=0;i<numberOfSensores ;i++){
      Serial.print(all[i];
      Serial.print(deliminter);
   Serial.println("");
   previousPrint = millis();
void writeHeader(){
  Serial.print("RPM");
 for(byte i=0;i<5 ;i++){
    Serial.print("PT");
    Serial.print(i);
    Serial.print("TE");
    Serial.print(i);
 for(byte i=0;i<2 ;i++){
    Serial.print("VF");
    Serial.print(i);
 Serial.println("");
void readPressures(){
   pressure[i] = map(readAnalog(pressurePins[i]),0,1023,0,pressureMax[i]);
void readTemperatures(){
   temperatur[i] = map(readAnalog(temperturePins[i]),0,1023,0,100);
void readVolumeFlow(){
   flow[i] = map(readAnalog(flowPins[i]),0,1023,0,flowMax[i]);
void moveServo(){
 servoPos = readAnalog(servoPot);
 if(servoDirection){
      servo.write(map(servoPos, 0,1023,minPos,maxPos));
 else{
      servo.write(map(servoPos, 0,1023,maxPos,minPos));
int readAnalog(byte pinNumber){
 for(byte i=0;i<4;i++){
        digitalWrite(pinSelect[i],logicArray[pinNumber][i]);
 delay(2);
 return analogRead(signal);
 void rpmRead()
  if (rpmcount >= numberOfSamples ) {
    //Update RPM every numberOfSamples  counts, increase this for better RPM resolution,
    //decrease for faster update
    rpm = 30*1000*rpmcount/(millis() - timeold);
    timeold = millis();
    rpmcount = 0;
    analogwrite(rpmDisplayPin,map(rpm,0,rpmMax,0,255);
 void rpm_fun()
  rpmcount++;
  //Each rotation, this interrupt function is run twice
Well, my first suggestion would be to separate constants and variables:
Something tells me only two of those arrays are constants.
And beware cut'n'paste programming. :wink:
Updateted the code as u told me to, thanks
Kim
Another thing is, you've got a lot of "2" and "5" literals scattered around - it would be a good idea to convert these to constants too.
How can i make it a one dimensional array and not a two dimmensional array?
As you are only storing 0 or 1's in the array then you can store them as bit patterns in bytes:-
                          {1,0,0,0},
                          {0,1,0,0},
                          {1,1,0,0},
                          {0,0,1,0},
                          {1,0,1,0},
                          {0,1,1,0},
                          {1,1,1,0},
                          {0,0,0,1},
                          {1,0,0,1},
                          {0,1,0,1},
                          {1,1,0,1},
                          {0,0,1,1},
                          {1,0,1,1},
                          {0,1,1,1},
                          {1,1,1,1}};
byte logicArray [16] = { 0,
                          8,
                          4,
                          12,
                          2,
                          10,
                          6,
                          14,
                          1,
                          9,
                          5,
                          13,
                          3,
                          11,
                          7,
                          15};
Then when you recover the byte just extract the appropriate bit.
something like this:-
int mask = 1;
int point;
        if((logicArray[i] & mask) != 0) point = 1; else point = 0;
        digitalWrite(pinSelect[i],point);
   mask = mask <<1;
 delay(2);
Note - not tested.
