Arrays in classes
Hi There,
I am looking for some help with arrays and classes. In my .h file I declare my array as so
private:
  int _pin;
  int _morseCode[3];
This should create an array with three int elements?
I have tried initializing this array in my constructor as follows:
_morseCode={1,2,3}
But this doesn't work, what am I doing wrong? Do I have to explicitly set each element?
All help is greatly appreciated.
If you have three values, shouldn't you have 4 places? have you tried int _morseCode[4] = {1,2,3}; ?
Joa
You only need extra elements in the case of strings, where you need an extra one for the terminating NULL.
I believe that an initializer like {1,2,3} only works when you declare the array. You can't use it as an assignment statement. You'll have to assign each element individually, like this:
_morseCode[0] = 1;
_morseCode[1] = 2;
_morseCode[2] = 3;
I have figured this out now, using the {1,2,3} when declaring the array works but it cannot be used as an assignment statement.
Thanks for all the help.
