I am using a TLC5940 LED driver chip and am trying to use arrays to switch the pins on. I have found plenty of examples to switch one pin on at once but i want to switch several on at once. I have the code below and when run it will turn on pin 3 as requested.
#include <Tlc5940.h>
void setup ()
int one[] = {1,3,5};
Tlc.init ();
Tlc.set (one[1], 2048);
while (Tlc.update ());
void loop ()
I wanted to turn on all three pins so i tried.
Tlc.set (one[0,1,2), 2048);
but that didn’t work, it only turned on pin 5 instead of all 3 pins as i expected.
I’m sure you can work out that i’m very new to this so can someone tell me if what i am trying to do is possible and if so where am i going wrong.
Thanks, Hiro.
