Arrays
Hi There,
I am very new to all of this and I have been working through the manual that came with the kit. I have come across arrays and it gave me an example which I followed. Everything has worked fine but I can’t understand why I have the output I do for Array 1. I have attached the code and I was wondering if someone can please explain why the output is 336.
Thanks in advance.
Arrays.ino (719 Bytes)
What were you expecting to see? What did you actually see? How did those two things differ?
For array 1 it should print out
1
2
3
4
because that’s what you set all four of the array values to.
OP’s code:
// Arrays
int Array_1[4];
int Array_2[]={5,2,9};
  Serial.println("Arduino Arrays");
  byte x;
  Array_1[0]=1;
  Array_1[1]=2;
  Array_1[2]=3;
  Array_1[3]=4;
  Serial.println("Output of Array 1 ");
  Serial.println("----------------");
  // Output the data of the first array
  for(x=0;x<4;x++);
    Serial.print(Array_1[x]);
  Serial.println("Output of Array 2 ");
  // Output the data of the second array
  Serial.print(Array_2[0]);
  Serial.print(Array_2[1]);
  Serial.print(Array_2[2]);
  while(1);
  for(x=0;x<4;x++);The trailing semicolon should not be there
I was expecting to see
1
2
3
4
Now I have removed the semicolon I have the result I expected Thank you for this.
Can someone explain why the semicolon created the result i ended up with?
The semicolon was the only code executed by the for loop
A for loop executes the next statement after. That can be a single statement, it can be a compound statement (many lines inside { and }) or it can even be the empty statement, the semicolon. The semicolon literally means, "Do nothing". So your for loop read, do "Nothing" 4 times. Without the semicolon the next thing after the for loop is the compound statement:
I understand now thank you for this, it has been a real help.
