Sorry, yes I've pulled everything else, and the last couple of tests were run with only the GLCD.
While under direct 5v only the display has less over all 'flicker' but it does still have the artifacts. I've typically only used it with with either USB or 5v power but not typically both. Should I test using both going forward? I don't think I ever hooked it up incorrectly.
Resoldered 6 and 11 because they do/did look a little sketchy but still failed with 5v power feed as well:
Serial initialized
GLCD Lib Configuration: glcd ver: 3 glcd_Device ver: 1 gText ver: 1
Panel Configuration:ks0108
Pin Configuration:ks0108-Mega
GLCD:ks0108 DisplayWidth:128 DisplayHeight:64
Chips:2 ChipWidth:64 ChipHeight:64
CSEL1:33(PIN_C4) CSEL2:34(PIN_C3)
RW:35(PIN_C2) DI:36(PIN_C1) EN:37(PIN_C0)
D0:22(PIN_A0) D1:23(PIN_A1) D2:24(PIN_A2) D3:25(PIN_A3)
D4:26(PIN_A4) D5:27(PIN_A5) D6:28(PIN_A6) D7:29(PIN_A7)
Delays: tDDR:1320 tAS:1140 tDSW:1200 tWH:1450 tWL:1450
ChipSelects: CHIP0:(33,0x1, 34,0x0) CHIP1:(33,0x0, 34,0x1)
Data mode: byte
Diag Loop: 1
Initializing GLCD
Displaying ChipSelect Screens
Walking 1s data test
Wr/Rd Chip Select Test
Testing GLCD memory pages
Horizonal Page Test Chip: 0 Pixels 0-63
Verify error: (0,0) 42!=81
Verify error: (2,0) 44!=43
Verify error: (3,0) 45!=44
Verify error: (4,0) 46!=45
Verify error: (5,0) 47!=46
Verify error: (6,0) 48!=47
Verify error: (7,0) 49!=48
Verify error: (8,0) 4A!=49
Verify error: (9,0) 4B!=4A
Verify error: (10,0) 4C!=4B
Verify error: (11,0) 4D!=4C
Vertical Page Test Chip: 0 Pixels 0-63
Verify error: (0,0) 5!=FD
Verify error: (61,0) F2!=FA
Verify error: (44,0) 6C!=74
Verify error: (12,0) 6E!=76
Verify error: (45,0) 79!=6D
Verify error: (62,0) 1!=9
Verify error: (6,0) 44!=4C
Verify error: (12,0) 72!=7A
Verify error: (61,0) FB!=3
Verify error: (63,0) 11!=19
Verify error: (32,0) 19!=21
Horizonal Page Test Chip: 1 Pixels 64-127
Vertical Page Test Chip: 1 Pixels 64-127
Full Module Horizontal Page Test:Pixels 0-127
Verify error: (29,0) 9D!=9E
Verify error: (42,0) 2A!=2B
Verify error: (60,0) 3E!=3F
Verify error: (8,0) 8A!=8B
Verify error: (19,0) 16!=17
Verify error: (0,0) 4!=43
Verify error: (63,0) 43!=42
Verify error: (0,0) 5!=44
Verify error: (57,0) 3E!=3D
Verify error: (58,0) 3F!=3E
Verify error: (59,0) 40!=3F
Full Module Vertical Page Test:Pixels 0-127
Verify error: (8,0) 43!=4B
Verify error: (2,0) 18!=20
Verify error: (58,0) DD!=E5
Verify error: (55,0) C4!=CC
Verify error: (25,0) DE!=E6
Verify error: (15,0) 90!=98
Verify error: (53,0) C4!=CC
Verify error: (16,0) 9D!=A5
Verify error: (41,0) 64!=6C
Verify error: (26,0) F1!=F9
Verify error: (58,0) EE!=F6
TEST FAILED
