Artnet class problem
Hi everybody.
I’m trying to use a library from GitHub from this link:
https://github.com/jasuper/artnet-to-ws2812-over-arduino
I’ve downloaded the code but when I compiled I get this error: “Artnet.h no such file”.
So I downloaded the library from the library manager and I get another error message:
using Artnet = class arduino::artnet::Manager {aka class arduino::artnet::Manager}’ has no member named ‘setArtDmxCallback’
I don’t know what I have to do.
Thank to All
You don't download the library FROM the library manager. You download the library USING the library manager. The library manager tells you WHERE you will be downloading a particular library/version from. It is important that you tell us that AND that you post your code that uses that library.
This is the code and I’ve included the library Artnet.h
#include <RingBuffer.h>
This example will receive multiple universes via Artnet and control a strip of ws2811 leds via
Adafruit's NeoPixel library: https://github.com/adafruit/Adafruit_NeoPixel
This example may be copied under the terms of the MIT license, see the LICENSE file for details
#include <Artnet.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
// Neopixel settings
const int numLeds = 150; // change for your setup
const int numberOfChannels = numLeds * 3; // Total number of channels you want to receive (1 led = 3 channels)
const byte dataPin = 13;
Adafruit_NeoPixel leds = Adafruit_NeoPixel(numLeds, dataPin, NEO_GRB + NEO_KHZ800);
// Artnet settings
Artnet artnet;
const int startUniverse = 1; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as 0.
// Check if we got all universes
const int maxUniverses = numberOfChannels / 512 + ((numberOfChannels % 512) ? 1 : 0);
bool universesReceived[maxUniverses];
bool sendFrame = 1;
int previousDataLength = 0;
// Change ip and mac address for your setup
byte ip[] = {2, 0, 0, 2};
byte mac[] = {0x08, 0xE9, 0xE5, 0x00, 0x69, 0xEC}; // make sure this is different than any other mac address in your network
  //Serial.begin(115200);
  artnet.begin(mac, ip);
  leds.begin();
  initTest();
  // this will be called for each packet received
  artnet.setArtDmxCallback(onDmxFrame);
  // we call the read function inside the loop
  artnet.read();
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data)
  sendFrame = 1;
  // set brightness of the whole strip
  if (universe == 15)
    leds.setBrightness(data[0]);
    leds.show();
  // Store which universe has got in
  if ((universe - startUniverse) < maxUniverses)
    universesReceived[universe - startUniverse] = 1;
  for (int i = 0 ; i < maxUniverses ; i++)
    if (universesReceived[i] == 0)
      //Serial.println("Broke");
      sendFrame = 0;
  // read universe and put into the right part of the display buffer
  for (int i = 0; i < length / 3; i++)
    int led = i + (universe - startUniverse) * (previousDataLength / 3);
    if (led < numLeds)
      leds.setPixelColor(led, data[i * 3], data[i * 3 + 1], data[i * 3 + 2]);
  previousDataLength = length;
  if (sendFrame)
    leds.show();
    // Reset universeReceived to 0
    memset(universesReceived, 0, maxUniverses);
void initTest()
  for (int i = 0 ; i < numLeds ; i++)
    leds.setPixelColor(i, 127, 0, 0);
  leds.show();
    leds.setPixelColor(i, 0, 127, 0);
  leds.show();
    leds.setPixelColor(i, 0, 0, 127);
  leds.show();
    leds.setPixelColor(i, 0, 0, 0);
  leds.show();
and I've included the library Artnet.h
That you got from where?
From the library manager. I've searched Artnet And I found a library and installed. Version: 0.1.0
https://github.com/hideakitai
The linked sketch seems to use either an older version of the Artnet library or a completely different library.
A Google search gave some evidence that this library was used.
Now I've the same problem on another library:Ringbuffer.h Is it better to find it or to find another project to use? Is there anyone that knows how to solve it?
are you sure the libraries are meant for the whatever Arduino you use?
Did you remove the library you installed in the IDE? Because if you didn't remove that one, it is still used, no matter what other library you may have installed.
