ey mcnobby!
I am trying out your amazing code, and it is working nicely, but there are 2 weirds things going on:
The first pixel is always displaying some degree of green, regardless what I send there is always a little bit of green. I tried different strips and I always get the same result.
Also, specially in the first pixel but not exclusively, there is some flickering. I trid with and without a 470Ohm resistor and it flickers both ways.
I copy the code as I am using it here:
SmartShow AirPixel ONE - Single Universe ArtNet to WS2812 Driver - For Wemos D1
You can set the Device IP, and universe number below
Works perfectly with Jinx LED software
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#define WSout 5 // Pin D1
#define WSbit (1<<WSout)
// ARTNET CODES
#define ARTNET_DATA 0x50
#define ARTNET_POLL 0x20
#define ARTNET_POLL_REPLY 0x21
#define ARTNET_PORT 6454
#define ARTNET_HEADER 17
WiFiUDP udp;
uint8_t uniData[514];
uint16_t uniSize;
uint8_t hData[ARTNET_HEADER + 1];
uint8_t net = 0;
uint8_t universe = 0;
uint8_t subnet = 0;
const char* ssid = "ARTNET_LINK";
const char* password = "M-Tork144";
IPAddress local_ip(2, 0, 0, 22);
IPAddress gateway_ip(2, 0, 0, 1);
IPAddress subnet_ip(255, 0, 0, 0);
delay(10);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
WiFi.config(local_ip, gateway_ip, subnet_ip);
Serial.print(".");
udp.begin(ARTNET_PORT); // Open ArtNet port
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
pinMode(WSout, OUTPUT);
void ICACHE_FLASH_ATTR sendWS() {
uint32_t writeBits;
uint8_t bitMask, time;
os_intr_lock();
for (uint16_t t = 0; t < uniSize; t++) { // outer loop counting bytes
bitMask = 0x80;
while (bitMask) {
// time=0ns : start by setting bit on
time = 4;
while (time--) {
WRITE_PERI_REG( 0x60000304, WSbit ); // do ON bits // T=0
if ( uniData[t] & bitMask ) {
writeBits = 0; // if this is a '1' keep the on time on for longer, so dont write an off bit
else {
writeBits = WSbit; // else it must be a zero, so write the off bit !
time = 4;
while (time--) {
WRITE_PERI_REG( 0x60000308, writeBits ); // do OFF bits // T='0' time 350ns
time = 6;
while (time--) {
WRITE_PERI_REG( 0x60000308, WSbit ); // switch all bits off T='1' time 700ns
// end of bite write time=1250ns
bitMask >>= 1;
os_intr_unlock();
if (udp.parsePacket()) {
udp.read(hData, ARTNET_HEADER + 1);
if ( hData[0] == 'A' && hData[1] == 'r' && hData[2] == 't' && hData[3] == '-' && hData[4] == 'N' && hData[5] == 'e' && hData[6] == 't') {
if ( hData[8] == 0x00 && hData[9] == ARTNET_DATA && hData[15] == net ) {
if ( hData[14] == (subnet << 4) + universe ) { // UNIVERSE
uniSize = (hData[16] << 8) + (hData[17]);
udp.read(uniData, uniSize);
//Serial.print("ArtNet packet RX Uni 0 - size:");
//Serial.println(uniSize);
sendWS();
} // if Artnet Data
Did you already posted the project that handles 32 universes?
Also, is there no way to control the rgb order in the sketch right? The order is not correct as we speak.
Thank you so much for this!
